Friends,
I'm a couple weeks away from my h/c/fast install and im trying to make sure im totally prepared. How many of you guys are running stock injectors with an aggresive h/c setup?
I have an 01 Z....parts going in are afr 205's milled to 58cc, ported fast 90/90, G6x3 cam, lg pro longtubes, halltech cai, slp u/d pulley, modded ti catback.
Do you guys think the stock squirters will do the job?
A lot of guys say its necessary. A couple of really good tuners told me the stock ones will go to 475 rwhp in N/A form with no problem. I argued this in the past with a guy who thought he needed them for his 430 rwhp car. He went ahead anyway and spent the money on injectors and a new dyno tune, and he didn't gain any power.
It sounds like your on target to be right at the edge of the stock injectors' capability, so I would step up now so you don't have to pay extra to retune later if your stockers aren't enough.
Much depends on your usage. When I had an LT1 C4 & ported the heads with a small cam, no headers, it was fine with the stock injectors. Until the day I took it on a road course and drove harder. Even shifting at 5000rpm to save the injectors, they blew (sharp drop in fuel economy post-event).
I have recorded my Injector Duty Cycle at 92% at peak RPM and I have bolt ons and a baby cam. Even I have thought about upgrading to larger injectors due to this. From what I hear you should not go about 90% but I have no idea why.
injectors are not designed to run with that kind of high pulse width....its an on/off part. when you leave it on 92% of any given time it tends to get hot. the more on time you have (high pwm) the harder you are working the injector.
I was told the 475 thing by Jeff Creech at CAM... he did a poor tune on my car, but this isn't about that. After the Creech tune my car made 424/378 and had horrible drivability I took the car to Ed Hutchings for a proper street/drivability tune. The car left with 436/396 but he showed me that my stock injectors were at 106% duty cycle at WOT.
Sure it'd be fine for a street car or once in a while drag strip run, but I was running HPDEs at the time. I had even done one on my crappy tune with the understanding that I was "fine until 475 rwhp". I'm lucky nothing went wrong.
I ended up going with 42lbers for room to grow if I ever put heads on the car. It's not about making more power, it's about having the correctly sized injector for the job.
Great topic. I have been asking myself the same question. I guess I will go with some new injectors as well. I already have cam but about to do a Heads/FAST install and I am trying to prepare everything as well.
