Should I replace Fuel Filter
Just wondering if at this mileage the filter would be clogged and I might have an issue on the dyno. If it wasnt 80 bucks Id do it as maint. without asking, on my 1998 it was 20 bucks I believe.
I'll change it just to be safe. Damn this car, it better put out every time I want after all this money haha
Changing the filter on 6 speed cars is a breeze with the quick-release tool....A4 cars are a B*TCH, even with the tool...It's difficult to get your hand (arm) up to where the filter is.....Keep in mind the filter was installed before the body went on..and engineers NEVER think about the poor fool that has to replace components down the road....
97 and 98 C5s take a simple, inexpensive, two fitting, filter (about $15)...99 thru 02 uses a more complex, more expensive three fitting filter (about $60)...some 03s and all 04s dont have a replaceable filter, it's in the tank...
What SUX is you must reuse the two plastic quick release connections (clips) on the inlet side of the filter (Ive never found a new one that included them..even GM filters dont have them)...These connections (clips) are easy to break, so be careful when removing them from the old filter.....
Also, it only takes a quick-release tool to remove the single "outlet" line (front) from the filter...the inlet lines use a quick-release connector, but they can usually be released by pinching the two clips together with your fingers....Thats IF you can get your hand up in there!!
NOTE:all of these fuel lines are PLASTIC...be VERY careful not to kink or damage them...if you do, you'll be in for a HUGE headache!!...AND, be EXTREMELY careful if youre using a drop light to see what youre doing under the car....when you release the fitting(s) you'll often get a shower of gasoline....One drop of gas on a hot drop light will set off a fireball that can burn your Vette (and maybe YOU) to the GROUND!!...Use a flashlight or neon drop light..
Change the filter it is cheap insurance
