Vararam or Blackwing?
Old Sep 22, 2008 | 08:38 PM
Nepthalim's Avatar
Nepthalim
Default Vararam or Blackwing?
I currently have a Vararam on my '03 coupe and I thought it was the greatest thing since sliced bread, however, I have read that alot of you guys have switched over to the Blackwing. I'm curious why those of you that had a Vararam made the switch to the Blackwing? Is it really that much better?
Old Sep 22, 2008 | 08:44 PM
warren s's Avatar
warren s
Where did you read alot about this?
Old Sep 22, 2008 | 08:48 PM
BUBBAS 01Z06's Avatar
BUBBAS 01Z06
Old Sep 22, 2008 | 08:52 PM
Nepthalim's Avatar
Nepthalim
Ok, I didn't write that correctly...I have read that a few guys say that the Blackwing is a better setup than the Vararam. I was curious as to how many made the switch over from the Vararam to the Blackwing and have they noticed anything different...
Old Sep 22, 2008 | 08:55 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Depends on if you want tip in or roll on
Peace
Chip
__________________
..................Click for
Old Sep 22, 2008 | 08:56 PM
Patches's Avatar
Patches
I switched from the BW to the Vararam on my MN6 and it is definitely a noticeable improvement. I installed a BW on the wife's A4 coupe last summer only because it was easier to install/maintain. I wasn't looking for every last bit of power on her setup - just a healthy boost in intake flow and the BW delivers there. If I were to choose top performer of the two it would be Vararam, no contest.
Old Sep 22, 2008 | 08:57 PM
warren s's Avatar
warren s
The Vararam provides more performance on the track and the time slips prove it, just go to any Corvette racing event.
The VR is more complex, has some build quaility issues and is much more involved to install. Some are fearfull of water getting into the engine in very rare cases.
The Blackwing is Ok, is easy to install and works well, just not as good. (Also doesnt cost that much less)
Old Sep 22, 2008 | 09:20 PM
DIXZ's Avatar
DIXZ
I switched from BW to Vararam. I noticed the difference. My intake air temperature is greatly improved.
By the way, I am a rare case in that I scan every weekend and most of my 1/4 mile runs!
Old Sep 22, 2008 | 09:29 PM
I had the Blackwing on mine and it performed very well for me. But everything I have read indicates the Vararam is the better of the two for performance gains.
Old Sep 22, 2008 | 09:47 PM
yaknow's Avatar
yaknow
Very satisfied with the vararam
Old Sep 22, 2008 | 10:42 PM
Ryan L's Avatar
Ryan L
Do you have apples-to-apples timeslips to post? I currently have a BW and the car runs smooth as eggs. I'd find it hard to believe that a VR will provide anything noticable, but I am open to suggestions.
Old Sep 22, 2008 | 11:50 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
The VR is seat of the pants you CAN feel!!!!!
Old Sep 23, 2008 | 12:23 AM
Ed_78Vette's Avatar
Ed_78Vette
My plans are the Blackwing for my 98 Coupe. The others may not be smog legal in CA.
Old Sep 23, 2008 | 12:39 AM
rws.1's Avatar
rws.1
Blackwing on my Wife's '04
VaraRam om my '01
My wife says the "01 is much faster and the '04 can be beaten by our TrailBlazer.....
Old Sep 23, 2008 | 01:09 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
The VR is the only true ram air cold air intake made. Most of the others use air from the radiator cavity. You have much less pressure using air from there because the radiator is a big hole creating much less pressure. Also sucking air from the radiator and ac condenser cavity can't be as cool as air sucked from the foglight holes. Not to mention air sucked up from the hot asphalt won't be as cool.
So the choice is fresh cool pressurized air or heated less pressurized air.
Old Sep 23, 2008 | 01:49 AM
Silverbullet00
Old Sep 23, 2008 | 09:08 PM
Shirl's Avatar
Shirl
2025 C8 of the Year Finalist - Modified
2021 C7 of the Year Finalist - Unmodified
Add Cold air screens with the Blackwing and the issue is taken care of. Cold air from the fog light area. You can also cut the covers open or drill holes. This setup definately gives a "seat of the pants" improvement over stock.
To Vararam or Blackwing?
Old Sep 24, 2008 | 02:22 AM
RedRckC5's Avatar
RedRckC5
Old Sep 25, 2008 | 01:54 AM
Riley P's Avatar
Riley P
Vararam=Varahappy
Old Sep 25, 2008 | 03:02 AM
kazza's Avatar
kazza
2nd Gear
lol
