Brass Gear Question ..... I know I'll Make it quick
Suggest going back to check your electrical connections -- especially the ground -- and look for a pinched or shorted wire.
You may have a problem with the insulators. there was a TSB out for that a few years ago and you need to fit replacement insulating washers. Here's the info:
Number: 00-08-42-002
Subject: Left Headlamp Door Does Not Stay Closed (Shim Headlamp Door Motor/Actuator and Replace Insulators)
Model Year: 2000 Chevrolet Corvette
Condition
Some customers may comment that the left front headlamp door does not remain closed after the headlamps are turned off. Others may comment
that the left headlamp door closes when the headlamps are turned off, but then reopens. In either case, the right headlamp door operates properly.
Correction
Important
The following information applies to the left front headlamp door motor/actuator only. It does not apply to and should not be performed on the right front headlamp door motor/actuator.
Install one washer (2) between the left headlamp door motor/actuator (1) and the mounting bracket (3) at each of the three attaching bolt locations. Also replace the
insulator (4) on each of the two mounting bracket travel stop tabs (5) as shown. For information on headlamp motor/actuator removal, see the Headlamp Motor/Actuator
Replacement procedure in the Lighting sub-section of Body & Accessories in the appropriate Service Manual.
Parts Information
Part Number Description Qty Per Vehicle
11505463 Washer 3
16524060 Insulator 2
Condition
Correction
Important
Parts Information
11505463 Washer 3
My vettes a 98, the motor I have had the removable cover on the motor. Any chance I installed the linkage backwards? I mean it's going up and down no problem, it just doesn't stop when it should. Maybe the stoppers? Going to have get me hands dirty again tonight.
HTH.
HTH.
HTH.
