Leaky butt fix need spring compressor?
Old Sep 23, 2008 | 09:49 PM
waunavet's Avatar
waunavet
St. Jude Donor '20
Default Leaky butt fix need spring compressor?
I'm getting conflicting information on how to replace the left diff. side cover o-ring and axle shaft seal. Do I need a spring compressor?
Old Sep 23, 2008 | 10:29 PM
Z06ster's Avatar
Z06ster
Not sure if I know the answer, but take a look at this thread I did a while ago when I had my leaky butt fixed....many gorey details. I have also posted a thread by Junkman2008 which should be helpful...
http://forums.corvetteforum.com/show...ght=leaky+butt
Old Sep 23, 2008 | 10:41 PM
erick_e's Avatar
erick_e
St. Jude Donor '13-'14-'15-'16
No, you do not need a spring compressor. After you remove the upper control arm bolts, the the half shaft will pull out of the differential. Then you can remove the side cover and replace the o-ring.
Old Sep 23, 2008 | 10:48 PM
waunavet's Avatar
waunavet
St. Jude Donor '20
Thanks. I've got a GM bulletin that calls for a spring compressor (theirs, of course).
Old Sep 24, 2008 | 02:45 AM
Last C5's Avatar
Last C5
You will need a stud puller to make removing the left cover a lot easier.
To Leaky butt fix need spring compressor?
