run flats
Old Sep 23, 2008 | 11:44 PM
rocco666's Avatar
rocco666
Default run flats
I just discovered a screw in my front passenger tire,,,, I have the oem goodyear run flats,,,, my question is ,,, when this screw comes out can the whole be patched or does it requir a new tire.... and if I need to get new tires,, which my time is coming, can you guys sudgest a good non run flat for a resonable price,,,, Im on a budget and want t get the best bang for my buck,,,, the c5 is not a daily driver,,, its a weekend and afternoon driver,,,,,,,,,,so what are my best options
Old Sep 24, 2008 | 12:02 AM
NorCalVette Kid's Avatar
NorCalVette Kid
St. Jude Donor '09
Michelin fun flats are a good alternative, a lot less expensive than Good Years and they ride better too!
Old Sep 24, 2008 | 12:05 AM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Forget about runflats,,,,they suck and cost way to much to ride and handle that bad! Go to tirerack and learn about your options then shop where you will!
Old Sep 24, 2008 | 06:22 AM
DAV162's Avatar
DAV162
Old Sep 24, 2008 | 07:47 AM
hk940's Avatar
hk940
i went with the Eagle F1 GS-D3.
it's a great tire and is a run flat. i know you want a non run flat but i would highly recommend you look at this tire.
Old Sep 24, 2008 | 09:49 AM
Dave68's Avatar
Dave68
The OEM runflats can be patched 2 times and still retain their speed rating.
BTW, The GSD3 is a non-runflat (and one of, if not the best out there). While Goodyear does make a GSD3 runflat, it is usually labeled as such. Runflat tires weigh up to 6 lbs more than non-runflats and special equipment/trained personnel are required to mount them without damaging the wheel. The best thing about non-runflats is the ride - much better!
Old Sep 24, 2008 | 10:15 AM
SSWEET's Avatar
SSWEET
If you are going to replace with runflats...Kumho makes a fairly good and less expensive runflat...If you are going to venture into the non runflat arena....check out General UHP's...mainly because you mentioned cost as a factor........
Old Sep 24, 2008 | 11:54 AM
UWEBABY's Avatar
UWEBABY
St. Jude Donor '06-'07-'08-'09
Kuhmo makes great non-run flats too. Bought a set for my c4. Never had a complaint.
To run flats
