need quick help for part numbers (leaf springs)
Old Sep 24, 2008 | 11:52 PM
blaCkvette6's Avatar
blaCkvette6
Default need quick help for part numbers (leaf springs)
so my rear leaf spring broke on my 98....
dealer entered my VIN.. it says that my car has "soft ride" leaf springs, part # 22146323 (this is for the rear).. they also said leaf springs from 98-02 would fit...
my car has the **** that that selects touring, sport, perf.. so "soft ride" vs "sport ride" refers to the leaf spring only i guess...
anyways, i found a used set, with part # 22171757..coming off a 2000 vette... can someone tell me if these are for "soft ride" or "sport ride" ??
also, IF it is sport ride, can i still install it on my car without any issues with handling, etc ?
thanks so much!
Old Sep 25, 2008 | 02:09 AM
blaCkvette6
bump.. need to know asap please...
Old Sep 25, 2008 | 04:41 AM
blaCkvette6
midnight crew bump. going to sleep, but need to know this info before noon ...
Old Sep 25, 2008 | 12:46 PM
blaCkvette6
ttt...............
Old Sep 25, 2008 | 01:00 PM
DeeGee's Avatar
DeeGee
Not sure if I can answer the question. The sport/tour/perf switch sets the ride control. Thats the ride setting for the F45 shocks on the older cars like mine. That, and AH, were an option early on. I'm struggling to work out why the leaf spring would be different. Despite the different shocks the leaf spring seems to be the same part # from the parts manual.
Now I could be wrong but given the lack of replies............
Old Sep 25, 2008 | 01:25 PM
FASST LN's Avatar
FASST LN
My 2000 base spring had part number: 22179019
The engraved/casting number was 22146484
http://forums.corvetteforum.com/show...556&highlight=
The GM part numbers for the different suspension springs are:
- Z06 Front spring: 22178729
- Z06 Rear spring: 22188038
- Z51 Front spring: 22178729 (note: same as Z06)
- Z51 Rear spring: 22179020
- Base Front Spring: 22178728
- Base Rear Spring: 22179019
http://ls1howto.com/index.php?article=20
Old Sep 25, 2008 | 01:26 PM
mtndv8's Avatar
mtndv8
http://www.gmpartshouse.com/
Call Gene!!!!!
Aloha
Michael
Old Sep 25, 2008 | 01:30 PM
FASST LN's Avatar
FASST LN
Come to think of it, I have a set of front and rear base springs sitting in my garage.
I swapped them for a ZO6 springs.
Where are you located?
Old Sep 27, 2008 | 06:18 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
Thank you very kindly for the referral. I would be happy to assist you.
To need quick help for part numbers (leaf springs)
