Light switch for underhood light
Old Sep 27, 2008 | 10:14 PM
boomie1's Avatar
boomie1
Default Light switch for underhood light
Is there a light switch for the underhood light? I couldn't find any switch, neither could I find any info about it in the manual. The light does not seem like its blown out also in case its supposed to autoswitch on.
~Boomie
Old Sep 27, 2008 | 10:17 PM
boomie1's Avatar
boomie1
my bad - should have done a search first
I'll check if the connection plugg is unplugged. The vanity lights work so the fuse should be fine.
~boomie
Old Sep 28, 2008 | 01:36 AM
Jistari's Avatar
Jistari
And when you get it working if you want to leave the hood open, dont worry, it will shut off by itself in 15 min.
Old Sep 28, 2008 | 03:45 AM
DeeGee's Avatar
DeeGee
Id bet its the connector thats unplugged. Maybe the PO pulled it at a show? Its towards the base of the hood.
If not its the #2 fuse (Monitored load) 10A:
Old Sep 28, 2008 | 06:29 AM
guppie's Avatar
guppie
St. Jude Donor '08
If you're looking to see if it's unplugged make sure you check both plugs. There's one right at the light under the hood liner. Mine was unplugged at both places.
Old Sep 28, 2008 | 08:29 PM
boomie1's Avatar
boomie1
yep, was the plug. It was pulled from the top side.. just didn't notice it.
Thanks all!
Old Sep 28, 2008 | 08:52 PM
RonJ's Avatar
RonJ
Or until someone opens a door, then another 15 minutes etc.
RonJ ...
Old Sep 28, 2008 | 11:30 PM
Glad it was a simple fix.
Old Sep 28, 2008 | 11:44 PM
tbar1963's Avatar
tbar1963
St. Jude Donor '08
So now I'm curious.....Is and where is the switch to turn on the underhood light??..Tom
Old Sep 29, 2008 | 06:42 AM
RonJ's Avatar
RonJ
No switch that I am aware of, that's why so many people disconnect the plug.
Wouldn't be difficult to put a simple inline switch in the circuit if you were so inclined.
RonJ ...
Old Sep 29, 2008 | 08:26 AM
moserbe's Avatar
moserbe
Old Sep 29, 2008 | 08:38 AM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
it's built into the lamp assembly. a mercury switch that activates when the hood opens
Old Sep 29, 2008 | 09:14 AM
ljthe2nd's Avatar
ljthe2nd
You are correct its a switch built into the lamp assembly. But I don't think it's a mercury switch, because if you remove the light from the hood and move it like it would be moving as if you were opening or closing the hood you can hear clicking (contacts opening and closing).
I removed mine to replace the #561 bulb and replace it with a 9 LED setup I bought from autolumination.com. I had to solder it in place because of the way the wire hooks are on the LED assembly. When installed they were at a 90 degree angle shining sideways instead of out.
Old Sep 29, 2008 | 10:28 AM
10U 99's Avatar
10U 99
you are correct, no mercury. I would imagine the EPA had something to do with that. It looks like the method is a sliding contact like a ball bearing or such. I wonder if the light comes on during a hard stop.
Old Sep 29, 2008 | 05:04 PM
borkg2006's Avatar
borkg2006
I added a minature ON-OFF rocker switch to the cable so that at shows, I can turn the darn light off.
Old Sep 29, 2008 | 05:07 PM
hotwheels57's Avatar
hotwheels57
There's a few after market sources that sell a plug & play switch/harness just in case you have excess money to spend...
Old Sep 29, 2008 | 05:16 PM
10U 99's Avatar
10U 99
it will shut it's self off in 15 minutes
To Light switch for underhood light
