[Z06] Comments on engine knock???
Old Jan 8, 2002 | 08:14 PM
z06 Rules's Avatar
z06 Rules
Default Comments on engine knock???
Has anyone noticed the knocking on the Z06 when you accelerate faster?
What causes it? Is it the low rating of the Fuel or something else.
Comments appreciated.
Old Jan 8, 2002 | 11:58 PM
newme's Avatar
newme
Default Re: Comments on engine knock??? (z06 Rules)
Never heard it on mine.
Of course I may be biased since usually while accelerating my uncontrollable wide grin pulls my fat cheeks backwards, which in turn squeeze my outer ear into an ellipse. ;)
Any particular gear / RPM range that this happens for you?
Old Jan 9, 2002 | 12:10 AM
ZO6LS6's Avatar
ZO6LS6
zo6, what kind of knocking, and where does it seem to be coming from......need details.........
Old Jan 9, 2002 | 12:11 AM
Dreamin's Avatar
Dreamin
Default Re: Comments on engine knock??? (newme)
My car definetly knocks (classic pinging/detonation sound) while accelerating with light load from 2K to 3K - no other place. It is 100% stock. I can only get 91 octance CA gas.
[Modified by Dreamin, 8:12 PM 1/8/2002]
Old Jan 9, 2002 | 12:24 AM
antirice's Avatar
antirice
Default Re: Comments on engine knock??? (Dreamin)
well does your car consume oil? you do know that oil will lower the flash point of gasoline wich will cause preignition. This is a common problem with cars that burn oil they get alot of knock retard. If you are burning oil get your car to the dealer and have it fixed.
[Modified by antirice, 3:38 PM 1/9/2002]
Old Jan 9, 2002 | 12:29 AM
newme's Avatar
newme
Sorry guys, just noticed that some of you are from CA... no idea what the lower octane effects might be so I'll shut up now...
Old Jan 9, 2002 | 01:38 AM
SWCDuke's Avatar
SWCDuke
I've run both LS1 and LS6 engines on 87 PON regular grade fuel in Southern California and never heard any audible detonation. The knock sensors should detect light detonation before you can hear it and switch to a correct ignition advance map for whatever grade of fuel you are using.
Go talk to your service advisor and ask him to read out any codes that might be present. Light detonation at part throttle is probably not going to hurt anything, but you might have an out of spec component in your engine management system.
Duke
Old Jan 9, 2002 | 02:55 AM
lovecars's Avatar
lovecars
Actually it's not real engine knock, it's the valve train around 3000rpm making noise, it's from the agressive cam, I think.
Ernie :D :D
Old Jan 9, 2002 | 03:34 AM
Dreamin's Avatar
Dreamin
Default Re: Comments on engine knock??? (lovecars)
I've just been procrastinating putting in 100 octane to figure out if it's knock once and for all... i'll do that this weekend...
No oil consumption... and the knocking sound is very, very mild.
Old Jan 9, 2002 | 09:39 AM
ZO6LS6's Avatar
ZO6LS6
zo6 rules..........where are you??.........you're Knocking may not be due to fuel at ALL.........pls respond with the TYPE & Location of the noise/s..........dull, sharp metallic/ clicking?............
It could be many things......not just pinging......especially if it is louder the faster you go........ :confused:
Old Jan 9, 2002 | 08:53 PM
z06 Rules's Avatar
z06 Rules
Default Re: Comments on engine knock??? (ZO6LS6)
I am in california where you could only get 91 octane and its not only my car a friend of mine has a z06 and he hadn't noticed it till I pointed it out. It happens on any given rpm if you step on the gas and the gearing is not at its full load. I think it comes from the valves compartment but I am not 100% sure about. It does sound like classic pinging. It is not that loud either.
Old Jan 9, 2002 | 09:12 PM
jeffsherman's Avatar
jeffsherman
My 2000 Convertible knocked at wot near red line, the dealer couldnt hear it - what a surprise. I believe it was caused by the k&N setup I used with the cold screens replacing the solid fog light panels. I think I was giving the engine more air than the program was set for and that could cause the engine to run lean. Lean mixture could easily cause the detonation. Have you changed anything on your car ? :nono:
I hav'nt experienced it yet on my new Z06 yet.
[Modified by jeffsherman, 1:13 AM 1/10/2002]
[Modified by jeffsherman, 1:14 AM 1/10/2002]
Old Jan 11, 2002 | 10:04 PM
ZO6LS6's Avatar
ZO6LS6
Default Re: Comments on engine knock??? (jeffsherman)
jefff,
don't think so.......you're rig would have done a relearn, and this shouldn't have been an issue or the cause......... :)
To Comments on engine knock???
