Help...belt walking forward
Old Oct 6, 2008 | 01:48 PM
jmorr649's Avatar
jmorr649
Default Help...belt walking forward
I need some help. There is some great information out here on belt replacements, etc. They have been most helpful. But I need a little help bringing this to my level.
I replaced my main serpentine belt last year cause it squeeled. Changed it with a Gatorback at the dealership...problem solved. Opened my hood the other day to change the oil and a third of my belt was left!!! So I went out and bought a new Gatorback and tossed it on myself. (Great write up on this on the forum...many thanks to those who wrote them)
Well I figured there was more to the story, but told myself to check and see where the problem will pop up over time. Well one day later the belt is walking forward on the tensioner (passanger side, moving forward towards front of car). So I come out and its hanging off the tensioner by 2 or 3 lines but on everything else. Thoughts? Is it the tensioner that is causing the issues you think? Or could it be something else?
Thanks for any help!
Old Oct 6, 2008 | 04:33 PM
c5streak's Avatar
c5streak
Better check your crank pulley/balancer. They are held on by a bolt that can loosen, allowing the balancer to " walk out" on the crankshaft, and many also wobble pretty bad. The balancer can also seperate from the rubber vibration damping material getting dry and failing. Also look for signs of the belt and/or pulley contacting the steering rack.
Old Oct 6, 2008 | 04:42 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Yep... first thing to check up on is the balancer. Your belt issue is indicative of pulley misallignment.
Old Oct 6, 2008 | 09:48 PM
bigbadfast's Avatar
bigbadfast
Are you bleeding any oil? I had a walking balancer and it killed the belt (shredded lengthwise), but the seal behind it cracked in half. Lots of oil spatter. Good luck with the fix.
Old Oct 6, 2008 | 10:05 PM
The NNIAL8R's Avatar
The NNIAL8R
St. Jude Donor '11,'13
"I voluntarily took 60 days off from OT"
From easiest to NIGHTMARE....
1. Faulty tensioner or idler pulley
2. Faulty harmonic balancer (crank pulley)
3. Faulty crankshaft thrust bearing...Unfortunately when the thrust bearing goes it usually damagaes the crankshaft to the point it will have to be reground or replaced.....This is a B*TCH...It will require pulling and major dissassemly of the engine....Easy way to check it...Place car on lift....Use a large prybar or screwdriver and pry between the crank balancer and engine....Does the entire cranshaft (not just the balancer) move fore and aft???..If so, break out the piggy bank....NOTE:This can be confused with a faulty balancer....Be certain to watch for the entire crankshaft to move fore and aft, not just the balancer..
I havent encountered this on a C5...but on many other vehicles..especially Fords and Dodges....But they all operate on the same principal...so dont rule it out....Dont waste $$$ on a balancer if you realy need a thrust bearing/crankshaft.....
Old Oct 7, 2008 | 08:54 AM
jmorr649's Avatar
jmorr649
Man thanks to you all. This is great feedback. I tried like crazy to get the balancer to move and it goes no where so I don't think its that, but like you said...can't be too sure.
I will let you all know what happens here.
Thanks!
Old Oct 7, 2008 | 09:51 AM
The NNIAL8R
Thanks!
If the balancer dosnt move replace the tensioner assembly....Its only about $100...Easy to replace....If the spring in it is weak it can allow the belt to jump track.......I havent seen a C5 with 50K miles that didnt need one anyway.......
To Help...belt walking forward
