Using CTECK with optima battery
Thanks,
Rob
The Red Top is an AGM battery. The advantage is because the absorbent glass mat holds the electrolyte material, they are less prone to leaks. Its not impossile but you' need to try really hard.
The down side is they don't like being discharged Once they have been discharged the often can'tbe coaxed back to life. My Vert sat on a boat to England for 8weeks and the Red Tp was DOA.
There's no problem with hooking a CTEK type charger to a Red Top. In fact it's advisable. I have my Yellow Top on a tender whenever it sits for longer than a week.
The other option is to disconnect the battery leads if you don't plan to use the car for 5 months. Under those conditions the battery will sit happily for that time. Pop the CTEK on for a few days before you disconnect and make sure the battery is fully charged. Then put it back on a few weeks before you plan to use it and you'll be good to go. If you do that, make sure you have the secuity code for the stock radio or turn the security feature off.
The rest is just marketing.
They leak and die just like other batteries.
Their design means they are less prone to leaking, and they are more vibration resistant, but they don't like being discharged and there are many posts of dead RedTops well within the warranty period.
Put a battery float charger on it
I prefer to leave the battery in the car, hooked up, in case of an emergency, were it needs to be moved out quickly.
"If the theft security light does not blink on the radio when turned of the code was not enabled and you don't have to do anything to unlock it after battery swap."
So I would start there, the security code is not something thats enabled by default (mine wasnt and I left it that way). A new owner has to turn it on, so your car may very well not have a security code enabled in the radio. Take a look.
This will get you a new code. You can “unlock” your radio and then “re-lock” it with a new code if you wish.
Radio must be in LOC mode NOT in INOP mode.
If you have activated the Theft-Deterrent feature of your radio and loose power, the radio goes into LOC (theftlock) mode. With the ignition on, you must use the MN and HR buttons to enter you personal code in order to unlock it (The instructions are on page 3-27 in your Y2K Owner’s manual). If you fail to enter the correct code eight (8) times, the radio goes into INOP mode. You have to wait an hour with the ignition on before the radio returns to LOC mode (go for a long drive somewhere).
Procedure:
01. Turn the ignition ON (The radio displays LOC)
02. Hold down the Radio Presets 2 and 3 buttons for six seconds
03. The radio display changes from LOC to a three-digit number. Write this number down. Don’t take forever, fifteen seconds max before the next step.
04. Press the AM/FM button
05. The radio display changes to another three-digit number. Write this number to the right of the first one.
06. You now have a six-digit number, the first three digits are from STEP 03 and the last three digits are form STEP 05
07. Call 1 800 537 5140 08. Press 1 then # (pound). You’ll hear “Invalid Code, try again”
09. Press 139010 then # (pound). You will be asked to enter your four or six digit code followed by * (start)
10. Enter the number from STEP 6 then * (star)
11. Listen to the four-digit number and write it down. It will be repeated twice
12. Turn the ignition ON (The radio displays LOC)
13. Use the MN and HR buttons to enter the code from STEP 11
14. Press the AM/FM button. The radio display changes to SEC Your radio is now “un-locked” and usable.
The Theft-Deterrent feature is STILL active! If you want to disable it, use the instruction on page 3-27 in your Owner’s manual. Use the code from STEP 11 instead of your personal code.
This tip originated from LOTZAHP.
On long trips I carry a charged battery jumper box in the trunk in case the yellow top decides to die at the wrong time.
