[Z06] Z06 Weight
Old Oct 13, 2008 | 08:21 PM
saleenmuscle's Avatar
saleenmuscle
Default Z06 Weight
Well I opened up My door today and noticed on the door where it has the VIN, and the tire pressure and all. It says the Z06 weighs a little over 3,500 lbs. It says frnt 1,7xx, rear 1,8xx. I thought it weighed just over 3,000 lbs? Anyone know whats up? Are ours cars really that fat. 02 z06 by the way stock pretty much
Old Oct 13, 2008 | 08:27 PM
Alaskanpilot's Avatar
Alaskanpilot
St. Jude Donor '08-'09-'10
I think you may be looking at the GVWR? (Gross Vehicle Weight Rating). That, I believe, is the maximum weight the car is rated for. So, it would likely include driver, passenger, and possibly a luggage and/or fuel allowance. The vehicle itself should be something like 3,115 pounds. I think mine is.
Like with airplanes: Our 737's have the equivalent of a GVWR, called Max Gross Takeoff Weight, which for us is 119,500 lbs. The plane itself only weighs 65,668 pounds.
Old Oct 13, 2008 | 09:13 PM
saleenmuscle
O ok that makes sense thanks!
Old Oct 13, 2008 | 10:53 PM
KING Z06's Avatar
KING Z06
i herd the z06 weight was around 3017 pounds could be wrong though
Old Oct 13, 2008 | 11:19 PM
UstaB-GS549's Avatar
UstaB-GS549
I just weighed mine on track scales:
844 843
724 698
3107
1/2 tank of fuel
B-K harness bar
GS wheels 17x9.5 and 17x11.5
Kumho V710 275 fronts nearly to the cords
Kumho V710 315 rears with lots of rubber.
If gauge was truly accurate: 9 gallons at 7 lb is 63 lb less for empty weight
Old Oct 14, 2008 | 12:30 AM
Alaskanpilot
OK, i just copied this from the Z06 Sticky at the top of this forum, But it doesn't address the configuration the car was weighed in: full tank or empty tank? I'm assuming it was weighed with all fluids topped off to spec, and in a completely stock setup.
"On the Z06 only, both the windshield and backlite have been thinned to save weight. But resistance to stone chipping has been maintained. A total of 5.7 pounds was eliminated. There is cabin quietness as a result. But in a car like the Z06, we don't think anyone will care. Reducing the Z06's overall weight, boosting its power output by 40 hp, and broadening its operating range, made a significant improvement in the car's power-to-weight ratio. All told, Z06 is the lightest Corvette 38 pounds lighter than the former hardtop, 99 pounds lighter than the 2001 coupe and 95 pounds lighter than the 2001 convertible at just 3115 pounds. And remember, it's all about power-to-weight ratio."
Old Oct 14, 2008 | 12:51 PM
slacker1201's Avatar
slacker1201
Lifetime NCM Member #2497
Cruise-In 9-10-11-12 Veteran
I just got mine weighed when I got an alignment, with a full tank of gas and my 220 pounds in the car it came in at 3236 pounds total.
To Z06 Weight
