wheels/tires question?
Old Oct 15, 2008 | 08:33 PM
vette6612's Avatar
vette6612
Default wheels/tires question?
I am new to owning a corvette so all information is appreciated. I just purchased a 1997 black corvette from my father in-law 12,500 miles for $13,000.00 I am hoping a got a good deal any thoughts on price paid? My question is I want to get new rims and I believe the stock sizes are front - 17 x 8.5 P245/45ZR17 and rear - 18 x 9.5 P275/40ZR18 I still have some good tread on the tires so I am looking to just replace the rims and remount the tires my question is do I need to stay with the same rim size as stock to keep my existing tires? That is what I am thinking and just looking for confirmation.
Old Oct 15, 2008 | 08:49 PM
Shirl's Avatar
Shirl
2025 C8 of the Year Finalist - Modified
2021 C7 of the Year Finalist - Unmodified
If you're keeping your tires you should probably get the same size rims or close to the same size. If you go a little larger with the width: 17x9.5 on the fronts, the tire will be a little more "stretched" so the sidewall will be less and the tire won't be as tall and the same goes for the back if you switch to an 18x10.5 wheel.
I'd leave them alone until the tires get worn out and then get new wheels/tires.
Old Oct 15, 2008 | 09:14 PM
mcrams's Avatar
mcrams
Sounds like a good deal. Do you have any pics, inside and out?
Old Oct 15, 2008 | 09:31 PM
vette6612's Avatar
vette6612
I will take some pics and get them posted the car is in really nice shape.
Old Oct 15, 2008 | 09:53 PM
NHRA_TA's Avatar
NHRA_TA
St. Jude Donor '10
Congrats on a great find!
Can't wait to see the pics!
Old Oct 16, 2008 | 05:10 AM
wdtiger's Avatar
wdtiger
Originally Posted by 8VETTE7
A few folk have tried to put the same size tire on all 4 and found the traction control starts going crazy because it thinks the rear tires are loosing traction because it expects the rear tires to be turning at a slower speed than the front.
What does it do? What do you mean by going crazy? Does this matter if you turn off the TC?
Old Oct 16, 2008 | 08:43 AM
steve8's Avatar
steve8
It sounds like a good deal to me.
If you want to use the same tires, then I would stay with the same size rims.
You can jump up to Z06 size wheels, 18's all around, or 18/19.
Yes, you do want to have some stagger in the sizes.
For instance, a 265/35/18 F, and a 295/35/18 R will work.
For a 13k dollar car, I can't see spending 3k on wheels, so I would lean towards repros. There are plenty to choose from for around 1K.
Good luck.
Old Oct 16, 2008 | 02:53 PM
Shirl's Avatar
Shirl
I have the same exact size wheels/tires all the way around. And haven't had any problems as of yet...
Old Oct 16, 2008 | 03:11 PM
steve8's Avatar
steve8
What size are you running?
Old Oct 16, 2008 | 03:27 PM
Mark-44's Avatar
Mark-44
Sounds like a great deal for a low mileage '97.
Don't blame you for wanting to swap the wheels...many owners have replaced those "Wagon Wheels" with the Y2K (2000 - 2004) style wheels.
Your eleven-year-old tires may look good, but are probably very hard and noisy; why not buy a good used set of wheels and new tires? I got a set of non-runflats and the ride improved greatly and can now hear my wife above the reduced tire noise.
Old Oct 16, 2008 | 08:29 PM
lefty77's Avatar
lefty77
Depending on the condition of that '97, that's a very good price! I bought my '97 Targa Top for $19k last summer and it had 49k miles on it, but in very good condition.
Old Oct 16, 2008 | 09:12 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I would be concerned that a tire that has been on a car for 12 years would be dried out. It may look okay on the sidewall, but how does it look between the treads? More than likely is it's dried out. 12K miles on a 12 year old car means it's been sitting for a long time.
Old Oct 17, 2008 | 07:59 AM
vette6612's Avatar
vette6612
Father in-law owned it and he flys between Pittsburgh and Myrtle Beach alot so he would only take it out only about 1 month out of the year during the summer. Drive it to work and that's about it. I will post pictures this weekend let me know what you think.
Old Oct 17, 2008 | 08:11 AM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
Sounds like a great deal you got. But, like others have said, I would be leary of those 12 yr. old tires. Sitting like that is not good for anything, especially rubber. I bet it's dried out and cracked between the treads. Check them out, and check the GP from VQMOTORING, if you're looking for new wheels.
They have some great new wheels and deals on tire/wheel combos.
Less than 1400 I think. Mounted, balanced, shipped to your door. Just have to have your TPMs switched to the new wheels, and you're all set.
I may be selling my C6 chromes with tires, if I order their new R279's.
Can't wait to see the pics.
Remember to wave!
Old Oct 17, 2008 | 09:09 AM
wdtiger's Avatar
wdtiger
Think about what the TC is supposed to do and you will answer your own question. It begins applying the rear brakes at very high brake-release rates to try and slow down the slipping wheels. It also closes the throttle and reduces spark if needed to reduce rear wheel speed. Last question answer is no if the traction control is turned off it doesn't matter. But why would you not want traction control turned on? It's a safety feature designed to help control the car under slippery conditions.
Thanks for the response. I did not know the TC system actively applied the brakes to help control wheel spin. I'm going from an '00 Z28 to an '00 FRC 'vette and already have a fresh set of race tires for the Z28. I've been planning to use the tires for next season.
Anyway, I live in Alaska and drive a RWD car in the winter and it has no TC (it's an '87 300ZX Turbo if you're curious ). I can handle no TC, i always drive with it off.
Thanks again!
Old Oct 17, 2008 | 12:07 PM
And you got a great deal on the car IMO. Very low mileage for a '97.
To wheels/tires question?
