Replacing my steering wheel
Old Oct 16, 2008 | 09:27 AM
Stomp'N'Go's Avatar
Stomp'N'Go
Default Replacing my steering wheel
Will this trip any codes with the airbag?
Old Oct 16, 2008 | 11:27 AM
Masterworks's Avatar
Masterworks
I did mine, you need an resistor thing (dont know the english word ) to connect there the airbag where connected!
Old Oct 16, 2008 | 11:30 AM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
Cruise-In 8-9-10-11 Veteran
CI 9, 10 & 11 Car Show Winner
St. Jude Donor '08-'10
I had mine swapped out the other day and watched him do it, and as long as you dont turn the key on while you are doing it, it shouldnt.
2 torx screws on the back of the wheel to remove the airbag, then remove the plug and ground, then steering wheel puller to pull it off the column.
Old Oct 16, 2008 | 11:45 AM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
I also removed the SDM fuse in the passenger side foot well fuse panel while removing/installing the airbag as a secondary precaution......
Old Oct 16, 2008 | 11:58 AM
Stomp'N'Go's Avatar
Stomp'N'Go
So the service manager says that he will have to reset the code after the install, could this possibly mess up my tune or would that be unrelated?
Old Oct 16, 2008 | 12:02 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Re-setting codes can be done through the DIC. As long as they don't flash the PCM, your tune should be fine.
Old Oct 16, 2008 | 12:48 PM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
I had no codes at all....gm tech did mine in the parking lot with hand tools.
Old Oct 16, 2008 | 01:00 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Peace
Chip
__________________
..................Click for
Old Oct 16, 2008 | 04:10 PM
BlueDream's Avatar
BlueDream
Changed mine out last year. No problems at all. Helped to have the GM steering wheel puller but other than that nothing special needed and no codes to worry about (I went with a factory type steering wheel so the airbag was reinstalled). I think there will be codes if you plan to not install the airbag on the new wheel.
Old Oct 16, 2008 | 04:26 PM
Stomp'N'Go's Avatar
Stomp'N'Go
Got a Vette Essentials wheel so I'll be keeping the airbag. I'm just gonna take it to the stealership, I don't have the time or the right tools right now..
Old Oct 16, 2008 | 04:58 PM
11SECSS's Avatar
11SECSS
can I have the stock wheel?? hehe but no seriously...
To Replacing my steering wheel
