[Z06] Intake - ????
Old Jan 10, 2002 | 11:35 AM
92SoonerC4's Avatar
92SoonerC4
Default Intake - ????
Which Intake setup should I get for my 01 Z06? I want one that I can remove and put my stock airbox back in if I need to, i.e. no major modifications to the stock setup, drilling and cutting.
TIA
Old Jan 10, 2002 | 12:01 PM
VettTheRipper's Avatar
VettTheRipper
Default Re: Intake - ???? (92SoonerC4)
Would have to recommend the HallTech T1 and I'm sure most ZO6ers would agree. Easy on, easy off, proven HP gains.
Old Jan 10, 2002 | 04:44 PM
pitrider's Avatar
pitrider
Default Re: Intake - ???? (VettTheRipper)
Halltech T1 sidewinder..very easy install,no cutting,looks and performance are awesome :chevy
Old Jan 10, 2002 | 05:34 PM
92SoonerC4's Avatar
92SoonerC4
Where do I buy the HallTech T1 at?
Old Jan 11, 2002 | 10:01 AM
VettTheRipper
Directly from HallTech. Here is the link to their site. http://www.corvettec5.com/ Get 1 quick, I think they're on sale.
Also there are a lot of posts on ZO6Vette.com forums about the Halltech system.
[Modified by VettTheRipper, 2:05 PM 1/11/2002]
Old Jan 11, 2002 | 01:01 PM
92SoonerC4's Avatar
92SoonerC4
Thanks, I ordered one. I wish they had 1 hour delivery, I am ready to install now.
Old Jan 11, 2002 | 01:05 PM
C5Longhorn's Avatar
C5Longhorn
If you don't want to cut or drill, then I would go for the Donaldson LS6.
Old Jan 11, 2002 | 05:11 PM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Default Re: Intake - ???? (rschiltz)
the Halltech T-1 has no drilling or cutting either.
:cheers:
Old Jan 11, 2002 | 05:43 PM
SMFCPACFP's Avatar
SMFCPACFP
Cruise-In II Veteran
Stick with the stock. It has all of the air flow the stock intake system needs. A lot of people selling products, or people who believe them will try to blow smoke about how much more hp this, or that intake system will give you, but the truth is - those little holes in the stock air cleaner are sufficient.
I made the mistake of buying the Donaldson Blackwing for more hp. THe fact is the hp gain was exactly zero.
It is a better air filter however, so I console myself with that fact.
Now if you want more hp, turbocharge your system.
Old Jan 11, 2002 | 06:21 PM
Ranger's Avatar
Ranger
Default Re: Intake - ???? (SMFCPACFP)
While SMFCPACFP has his own experience, I have mine. I did the measurements of gain on my Halltech Tric which is a bottom-breather. On before- and after- dynos it made a net +10 rwhp and +15 rwtorque. I like the results. AND I like the noise the intake makes at WOT.
Ranger
To Intake - ????
