based to explanations I'd guess that C5 is a negative offset....
Anyway,which rim would stick out more-the 56 0r 45 offset?
I don't want to get new wheels that would be to much inside the fenders...
Well, on my C5 I have had 4 different set of wheels, the first three look horrible.....the rear tires will stick out. Then I purchased a set of CCW Classics and Ilove the look of them. The offset is perfect! !
Here is a scheme which can help you. And wheels on C5 are positive offset. So the 45 offset will stick out more than the 56
