Shift boot ring glue not coming offf
Old Oct 19, 2008 | 06:41 PM
boomie1's Avatar
boomie1
Default Shift boot ring glue not coming offf
Trying to change the shift boot and the old one is glued on really tight on to the ring. No amount of pulling or prying is making it come out. The staples did come out easy though.
Any tips on how to take it out?
Last resort seems to cut the old boot and glue/staple the new one on top. It seems there is enough clearance for that to work but trying to remove the older one intact.
Thanks!
~Boomie
Old Oct 19, 2008 | 06:59 PM
mjmc1273's Avatar
mjmc1273
If it is an automatic, the shift boot is fastened with a nylon tie strap. Just turn the boot inside out, and cut the the tie strap. I am not sure about the manual's, but assume it would be a similar setup....
For complete instructions on how to remove boots for Auto or Manuals:
http://www.vetteessentials.com/instr...structions.htm
Old Oct 19, 2008 | 07:19 PM
boomie1's Avatar
boomie1
its manual. just pulling and tugging doesn't seem to work at all.
Old Oct 20, 2008 | 01:06 AM
boomie1's Avatar
boomie1
ttt
Old Oct 20, 2008 | 04:37 AM
01Z06 Black's Avatar
01Z06 Black
St. Jude Donor '08
Pull the staples.
Pull back the boot from the inside of the ring, and use a razor blade to cut the old boot from the ring.
Do not break the plastic ring.
Old Oct 20, 2008 | 06:12 AM
homewrecker's Avatar
homewrecker
Originally Posted by 01Z06 Black
Pull the staples.
Do not break the plastic ring!
Old Oct 22, 2008 | 02:20 PM
boomie1's Avatar
boomie1
tried really hard but wouldn't work . So i ended up cutting the original boot off first and then slowly used a sharp knife to get the stuck portions off.
Cracked the ring a teeny weeny bit but I think it will withstand
Old Oct 23, 2008 | 03:51 AM
IDM's Avatar
IDM
he said Do not break the plastic ring!
Old Oct 23, 2008 | 04:29 AM
01Z06 Black
St. Jude Donor '08
A little break is OK.
To Shift boot ring glue not coming offf
