Engine noise
Old Oct 20, 2008 | 12:48 PM
brasher801's Avatar
brasher801
Default Engine noise
on a 2001 is it normal to hear the fuel injectors in the car. I can hear them clicking if the radio is off in the car.
Also I started the car yesterday morning and heard what sounded like a rattle when I started it. (kind of like the old Ford rattle on some trucks when they had a little wear on them) After idle for a couple of minutes I drove it all day with no sign of any other rattle. Any idea???? The rattle was only for about 3-4 seconds right after start. The oil has just been changed and is full.
Thanks in advance for the feed back.
Old Oct 20, 2008 | 01:34 PM
D Baize's Avatar
D Baize
Are you useing low octane gas? Could be knocking from bad gas. possibly.
Old Oct 20, 2008 | 01:59 PM
brasher801's Avatar
brasher801
could be but it only did it once right after start up.
Old Oct 20, 2008 | 03:01 PM
killain's Avatar
killain
Oldtimer
My LS-1 in my 2003 is a little noisy in the morning, both a valve train and piston slap combination. But the fuel injectors are quiet?
Old Oct 20, 2008 | 03:57 PM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
the rattle that soon went away is most likely piston slap. LS motors are infamous for this condition, corrected in later assemblies. nothing to worry about until it persists after the engine has reach operating temps.
Old Oct 20, 2008 | 04:14 PM
brasher801's Avatar
brasher801
Any way to correct this problem? Or will it live a long and healthy life with this condition?
Old Oct 21, 2008 | 09:09 AM
RSchleder's Avatar
RSchleder
Default Don't worry about it!
Very common in the early LS engines. My 2000 clicks away when I first start it and after it warms up a bit quiets down to a acceptable level. It's done it since I bought it ( 38,000 miles) and hasn't changed in the past 30,000 miles.
Old Oct 21, 2008 | 09:32 AM
bobby777's Avatar
bobby777
fuel inj..piston slap very normal but should all go away after warm up--at idle still might hear injectors but no piston slap--keep your oil fresh
Old Oct 21, 2008 | 09:37 AM
homewrecker's Avatar
homewrecker
Old Oct 21, 2008 | 10:44 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I've heard a lot of people talk about piston-slap when starting a cold engine and my concern for those is that they are mis-interpretting the sound. If its a tapping sound that goes away anywhere from a few seconds to a minute and the tapping sounds are up high, then its the lifters.
The lifters do wear out over time, usually over 200K miles. If its the lifters, it'll probably start out with a few seconds of tapping and slowly get worse, taking longer and longer for the tapping to go away.
Old Oct 21, 2008 | 12:02 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Old Oct 21, 2008 | 01:17 PM
poolboy's Avatar
poolboy
there is a link here (http://pistonslap.com/) where you can compare the sound you're hearing with piston slap...
To Engine noise
