washer fluid low message
Oct 21, 2008 | 02:59 PM
6th Gear
low washer fluid message on screen. put in new sensor and still get the same message. i would appreciate any help
Oct 21, 2008 | 03:41 PM
Did you put any washer fluid in it? Sorry had to ask.
Oct 21, 2008 | 03:51 PM
St. Jude Donor '17
Ahhhh...........like........fill it up....and stuff maybe....
Oct 21, 2008 | 03:53 PM
Are you parking on an incline?
If not, try cleaning up the connection. Have to admit I've had the odd spurious message over the years.
Oct 21, 2008 | 04:07 PM
Is the sensor turned the right way? I have put mine in the side of the tank upside down in the past and continued to get the message.
Oct 21, 2008 | 04:50 PM
I agree with BlueDream Check if you put the sensor in the correct way. I had the same issue.
Oct 21, 2008 | 05:18 PM
CI 7, 9, 10 & 11 Veteran
St. Jude Donor '08-'09-'10
I believe in the Beer Fairy
check your blinker fluid too
Oct 21, 2008 | 07:23 PM
I get that on hard accelleration, and yes, its normal to see some come out even if you havent touched the washer when you accellerate hard.
Oct 21, 2008 | 07:56 PM
That's kind of funny installing it upside down. Wouldn't that be aggravating.
When you removed the old part did you install the new one exactly the same?
