C5 car ramps
Old Oct 21, 2008 | 11:00 PM
holley505's Avatar
holley505
Default C5 car ramps
Just wondering what brands or what types of ramps people are using to pull your vettes of the ground.
C5s are pretty low... and I wanna change my own oil safely. Also something that will not slide on the garage floor.
Old Oct 21, 2008 | 11:01 PM
Blackpixi7's Avatar
Blackpixi7
Look up the product "race ramps"
Old Oct 21, 2008 | 11:04 PM
Mad Dog Peter's Avatar
Mad Dog Peter
Better get out your wallet or head out to the lumber store. You either build your own or get the race ramps. OR... you get the cheap Rhino ramps and customize them with wood so the air dams don't scrape....
Or... you find a guy with a lift to do it all for you, LOL...
Old Oct 21, 2008 | 11:15 PM
Chicago's Avatar
Chicago
St. Jude Donor '15
The gray Rhino ramps and some 2x12's do the trick just fine.
Old Oct 27, 2008 | 04:36 PM
GR8-LIFE's Avatar
GR8-LIFE
I think the Race Ramps are pretty cool Looking. But they can be expensive even for simple drive ons to a lift, not worth it if you dont have a lowered car. But if you have a lowered car you will need ramps that are no greater than 7 degrees and rhino ramps wont accomodate you. So the Race ramps would do the trick
I remember when I bought a midsize lift like 3.5 years ago. My problem was getting some ramps that were 10-11 feet in length and 3" high so that my lowered car can clear the entire lift. There were some long 1 piece aluminum ramps but they were very expensive based on my specs. One company wanted $1250 and that was a time when aluminum was cheap
So I bought aluminum ramps (with rungs) designed to load tractors onto trucks. Each ramp is 14" wide and 5' 6" in length. So I needed 2 in length to accomodate the length of the vette. Then I needed 2 more on top of those 2 to get the 3" clearance because each ramp was only about 1.5" in height. Thats 4 ramps in total but for only 1 side. So I needed 4 more
The rungs obviously are not a smooth surface for drive on but I solved that by permanently affixing 3/4" boards (4 boards in total). And Awhile back Harbor freight had a great sale on these ramps. The entire solution to get 11 feet of ramp and the necesssary clearance over my lift was only $162. As far as getting the car onto alumium ramps, I personally use 2 feet of home-made wooden ramps. They might even be able to come up with a product where the 4 foot incline ramp safely joins the 10 foot/3.5" high (Or greater) ramp
I initially tried the long and heavy 12" wide wood but the pressure treated was too heavy to move and I didnt want the ugliness permamanently on my race deck floor
It would be really nice if Race Ramps can make 2 long Race Ramps (1 for each side) that have a 5-6 degree approach angle. This incline will be about 4 feet in length until it reaches 3.5" or greater. Then the remainder of the ramp will extend out about 10 1/2 too 11 feet (enough so that the car can fit. They would do very nicely to replace what I currently have to get over my lift. But they would be mega expensive to make. Just the shipping alone wouldnt be cheap. But they would look something like this.
Old Oct 27, 2008 | 04:49 PM
Kale's Avatar
Kale
Kwiklift.
Old Oct 27, 2008 | 07:34 PM
Mike Mercury's Avatar
Mike Mercury
carpenters ramps
http://mikemercury.home.att.net/ramp.htm
Old Oct 27, 2008 | 08:00 PM
coxjajb's Avatar
coxjajb
I use Rhino ramps.
Old Oct 27, 2008 | 08:10 PM
homewrecker's Avatar
homewrecker
Originally Posted by Mike Mercury
I like what you did there!
Old Oct 27, 2008 | 09:52 PM
GR8-LIFE's Avatar
GR8-LIFE
changing from 9 to 15 degrees was actually pretty clever to achieve the 10" height. 15 degrees might be a problem for some lowered cars, especialy if they have front spoilers for sure. But this is a pretty nice job. Now you get to work under the car without paying alot off $$$ for some of those lifts.
Old Oct 27, 2008 | 10:13 PM
Wheelboyo's Avatar
Wheelboyo
I just used my MM Carpenter Ramps (good one MM! ) a few days ago to change my oil. Mine are the Mike T. ones. Perfection!
Hey, looky here!
Old Oct 27, 2008 | 11:20 PM
Dave68's Avatar
Dave68
If you have NOT lowered your C5, Walmart has a nice set of 12,000 lb capacity ramps for $40 that'll work just great. You may have to place a welcome mat under the back of each so they don't slip.
If you lower your C5, you can make a pair of Mercury ramps or even easier, get some 6x6 and some 2x6 pieces to make very low angle ramps that get the front (and rear if necessary) up high enough to get your floor jack under the middle of the front cross member. These ramps don't need to be as wide or wider than your tires, since they are only temporary. Don't forget to use wheel chocks!
Old Oct 27, 2008 | 11:29 PM
thetaxman's Avatar
thetaxman
I have Rhino ramps , they are by far more cost effective than race ramps.
I also have a scissors lift similar to an above post.
I use wood ramps as he did but placed rollers on one end to make them easy to move.
(2) 1' X 2" X 14' screwed and glued together with a 45 degree angle cut on one end.
Rollers on the other end.
The rollers don't touch the floor when they are layed down flat.
I also put handles on the sides of them.
This all works for me and is cost effective.
Old Oct 28, 2008 | 01:32 AM
flyzlow's Avatar
flyzlow
Default Until I can afford Race Ramps...
I will send the plans for building these for free to anyone interested
Old Oct 28, 2008 | 10:23 AM
JimZRyd's Avatar
JimZRyd
St. Jude Donor '12
Love 'em!
Old Oct 28, 2008 | 11:12 AM
Mike Mercury
it was more necessity than clever. To maintain the 9 degree rise... but reach a 10" lift heigth... the ramps would almost be as long as the car (and a lot heavier).
Old Oct 28, 2008 | 11:17 AM
Mike Mercury
Originally Posted by Wheelboyo
Hey, looky here!
nice piece of engineering there
To C5 car ramps
Old Oct 28, 2008 | 03:12 PM
I used the black Rhino Ramps on mine.
Old Oct 28, 2008 | 07:56 PM
powderski13's Avatar
powderski13
They are much more expensive but very light weight and well built. I needed the long version with the extenders for my lowered 02 vert.
Old Oct 28, 2008 | 08:03 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
I bought a 4 post drive on lift with a jack tray this past year. After many years lying on my back, this is the best money I ever spent. If you have the ceiling height they are a great tool. The prices have really come down as well.
