My $1.00 GPS Mount.
It just won't stick any more.
Leaving it stuck to the windshield during the summer while on vacation was not one of my better moves.
I was searching on CF the other night and saw a really nice mount that "TNX ZORA" made out of sheetmetal.
See post #17 in this thread -
http://forums.corvetteforum.com/show...ight=gps+mount
I know there are some really nice options out there from the online vendors and such. I even saw something that might work for the GPS units that don't have the antenna sticking out the back like mine does. It was at Walmart for just under $15.00. It was right next to their GPS units. It was similar to those device mounts that "squeeze" to hold the device, but it was horizontal to hold the GPS and could be attached to the AC vent using clips. I tried to find a pic and a link but am unable to come up with anything right now.
So tonight when I was in Walmart I saw a $1.00 plastic box and brought it home to try.
It's crude and it's a bit flimsy especially compared to the sheetmetal one above.
However, its readily available and it was fun to re-engineer something.
Perhaps a wider piece would have less fore and aft play?
I will probably go back with something a bit more stout than this.
If I can get a scrap piece of sheetmetal and a brake to bent it, I may go that route.
This just slips in on top of the center air vent, but beneath the dash pad.
Thanks TNX ZORA for the idea.
The $1.00 donor plastic box.
I cut out a piece from the side of the box.
Plenty of surface area to mount the GPS to.
I used a heat gun and heated the preformed bend.
This allowed me to decrease the angle from the original shape and point the GPS straighter rather than down once installed.
Here I notched out the plastic to fit the GPS mount itself.
Test fit in the car.
The rubber band is holding the GPS to the plastic until I get some double-faced tape or some other method to hold the unit in.
The next two pictures show the GPS without the stock mount installed.
Perhaps I don't actually need the Garmin mount?
John@autobuffs.net
Auto Buffs LLC.
2 Kerry Ct,; Suite E
Southampton, NJ 08088
609-859-0900
www.autobuffs.net
Authorized IFORGED Dealer
Custom Painting & Airbrushing
Pinstriping
Car Audio
Mobile Electronics & Video
Remote Car Starters / Alarms
Use a rattle can lid and trim it to fit in your cupholder. Put velcro on the top. Fasten the suction cup holder to the plate that sticks on the dash, and put velcro on the bottom of it. Velcro the GPS to the paint can lid. Voila!!
I have the lid in several cars and can switch the GPS easily from car to car. Here's a not-to-good photo.
There was a lot of glare from the rear coupe window.
Some sort of adjustment would have been nice.
It did move around a bit much for my taste.
I will either redo the mount with a thicker piece of plastic or use some sheetmetal I got from a buddy yesterday.
Back to the drawing board.
I just copied you.
