I installed and it was working great, but had to unplug my battery when installing meziere. When I went to use the IPOD it wouldn't start right away, then it would work, then the horrible ERR and then it would go dead.
I pulled the radio and checked the connections, all was well. Then, while it was playing (and screwing up) i flipped the #3 trigger on the back of the unit on then off. It started working fine and hasn't had a problem since.
I looked for this specific tip in the Search and didn't find it. Hope it can help someone.
Thank you so much!!! My battery went dead over the winter, and I was having the same problem. I just tried your fix, and it seems to be working fine now.
