Driver side mirror issue!!!
Old Nov 3, 2008 | 08:29 PM
XRecon's Avatar
XRecon
Default Driver side mirror issue!!!
Please forgive my ignorance if this is a common issue on vettes but I can't find any info on it.
My driver side mirror has what appears to be a permanant frost on it. No matter how many times I wipe it it will not go away.
I believe my 01 came w/ an auto dimming feature but that wouldn't have anything to do with the mirror clouding up would it? Thanks in advance.
Old Nov 23, 2008 | 11:56 AM
ZR1.....someday!'s Avatar
ZR1.....someday!
4th Gear
I have the same problem, only my '03 electrochromatic left-hand mirror is about 90% "frosted". It's gotten steadily worse over the past few months. I don't know what caused it, but I'm trying to find out how to replace it. Does anyone know how to remove and replace the mirror? Thanks in advance.
Old Nov 23, 2008 | 11:58 AM
DeeGee's Avatar
DeeGee
It's delaminating. You can buy an approved GM spare for the mirror glass and it's easy to replace
The cheapskate solution is to buy a piece of the stick on mirror from WalMart. You'd lose the electro-chromatic dimming though.
$ or $$$$$$$$$$$$$$$$$$ thats the question.
Old Nov 23, 2008 | 12:09 PM
ZR1.....someday!
4th Gear
Thanks for the quick response. I definitely don't want to go with the stick-on approach. Do you know if the mirror housing has to be taken off the door? If not, how can the mirror itself be removed?
Old Nov 23, 2008 | 01:05 PM
DeeGee's Avatar
DeeGee
From the book:
Push in on one edge of the mirror glass tilting the mmirror case to allow finger access
Grasp the glass case firmly and pull the case from the mirror body
Disconnect the wire connectors from the case (heated mirror)
Remove the two jackscrews from the mirror glass case
Bend the jackscrew over
Press down on the side of the jackscrew popping the jackscrew from the mirror glass case
Save the jackscrews for reinstallation to the mirror motor.
The installation is a bit more complicated but if you decide to go that way I can send the instructions from the manual.
To Driver side mirror issue!!!
