Dead steady idle
Old Nov 4, 2008 | 11:04 AM
Shore's Avatar
Shore
Default Dead steady idle
Turn the A/C on and it gets almost non-noticeable.A/C off she gets the slightest roughness.Nothing bad or troublesome but I've certainly felt smoother.
Otherwise, she runs/revs perfect.
I keep reading this is semi normal or should I chase down the issue.I hate fixing stuff that isn't broken.Always ends up being a great way to break stuff or cause problems.
Old Nov 4, 2008 | 11:31 AM
BUBBAS 01Z06's Avatar
BUBBAS 01Z06
Its normal....
However....I have seen ARUN@CDNPERF rectify this problem on my car by tuning it out
Old Nov 4, 2008 | 11:53 AM
bucwheat's Avatar
bucwheat
All the C-5's I have been around have a slight ruff Idle anyway.
Old Nov 4, 2008 | 12:23 PM
SebringSixSpeed's Avatar
SebringSixSpeed
Call me crazy but personallly I like the slightly rough idle. Most V8 cars I've owned had a rougher idle than my C5.
Old Nov 4, 2008 | 01:11 PM
Shore's Avatar
Shore
I have previously wiped the TB down while on the car and I was almost ready to take it off and give it a good cleaning...I might do it anyways.
I had an occasional miss during idle conditons..very sporadic and only at idle.That turned out to be a plug wire that managed to walk itself halfway off the coil pack.Soon as I puled the FRC's off it was obvious.
I still might pull the TB and just clean it out.I doubt it's been done in some time.
Old Nov 4, 2008 | 03:46 PM
Shore's Avatar
Shore
Went ahead and removed the TB.Did the bypass while I had it off.
I'll be damned...it runs smoother.The TB wasn't bad but had some thick build-up on the intake side of the housing.Certainly from the stock PCV set-up.
To Dead steady idle
