[Z06] grinding noise ?????
Old Nov 5, 2008 | 10:16 AM
butchvette's Avatar
butchvette
St. Jude Donor '09
Default grinding noise ?????
i have a grinding noise that occurs when the speeed is over 55mph. I can feel the grind by touching the shifter. it only happens when the pedal is loaded, the grind goes away if i let off. I replaced the rearend fluid w/c was dirty, but no luck. any opinion will be much appreciated....tyvm
Old Nov 5, 2008 | 04:34 PM
ctusser's Avatar
ctusser
How many miles? Could be torque tube bushings.
Old Nov 5, 2008 | 04:41 PM
slvrzo6's Avatar
slvrzo6
Do you have an After Market Shifter?
If you do and your shifter has Solid Mount Shifter Bushings installed, or you do not have a Vibration Isolated Shifter you will get noise's and Vibration threw the shifter.
To grinding noise ?????
