[Z06] Trick Flow Top End
Old Nov 8, 2008 | 04:07 PM
samsvette's Avatar
samsvette
Default Trick Flow Top End
Trick Flow Specialties TFS-K306-515-460 $3,099.95
Estimated Ship Date: Monday
Brand: Trick Flow Specialties
Product Line: Trick Flow® 515 HP GenX (TM) Top-End Engine Kits for GM LS1
Part Type: Cylinder Head Combos
Part Number: TFS-K306-515-460
Camshaft Included: Yes
Intake Manifold Included: No
Fuel Delivery Style: Fuel injected
Timing Chain and Gears Included: No
Lifters Included: No
Gaskets Included: Yes
Cylinder Head Style: Assembled
Cylinder Head Material: Aluminum
Cylinder Head Finish: Natural
Combustion Chamber Volume (cc): 64
CNC-Machined Combustion Chamber: Yes
Intake Runner Volume (cc): 215cc
Exhaust Runner Volume (cc): 80cc
CNC-Machined Intake Runner: Yes
CNC-Machined Exhaust Runner: Yes
Intake Port Location: Standard
Intake Port Shape: Cathedral
Exhaust Port Shape: Oval
Exhaust Port Location: Standard
Intake Valves Included: Yes
Intake Valve Diameter (in): 2.040 in.
Exhaust Valves Included: Yes
Exhaust Valve Diameter (in): 1.575 in.
Intake Valve Angle: 13.50
Exhaust Valve Angle: 13.50
Valve Springs Included: Yes
Outside Diameter of Outer Spring (in): 1.300 in.
Damper Spring Included: No
Number of Springs Per Valve: Dual
Retainers Included: Yes
Retainer Material: Titanium
Locks Included: Yes
Lock Style: 7 degree
Valve Stem Seals Included: Yes
Valve Stem Seal Material: Viton® fluoroelastomer
Rocker Arms Included: Yes
Rocker Arm Studs Included: No
Rocker Arm Nuts Included: No
Guideplates Included: No
Pushrods Included: Yes
Valve Covers Included: No
Valve Cover Mounting Style: Centerbolt
Accessory Bolt Holes Drilled: Yes
Valve Guides Included: Yes
Valve Guide Material: Bronze
Valve Seats Machined: Yes
Valve Seat Machine Style: 3-angle
Valve Seat Material: Ductile iron
Steam Holes Drilled: No
Oiling Style: Through pushrod
Machined for O-Ring: No
Heat Crossover: No
Cylinder Head Bolts Included: Yes
Quantity: Sold as a kit.
Notes: Camshaft specs are 228/230 duration, .585 in./.585 in. lift, 112 lobe separation angle. 1997-98 model engines require the purchase of centerbolt valve covers. Trick Flow recommends this kit be used with at least 10.5:1 compression and a LS6 or FAST 90mm intake manifold. Aftermarket tuning is required.
Head Combo, GenX (TM) Top-End, 515 HP/460 ft.-lbs. Torque, Chevy, Small Block, LS1, Kit
Each kit includes:
* Pair of Trick Flow® GenX (TM) street/strip cylinder heads
* Specially matched hydraulic roller cam
* Roller rocker arms
* Pushrods
* Head gaskets
* Head bolts
* Exhaust gaskets
* Balancer bolt
Has anyone on here purchased this kit, Would it fit on my 03Z ? For roughly $3100 dollars it seems you can gain quiete a bit!
Old Nov 8, 2008 | 08:04 PM
Z06_BluByU's Avatar
Z06_BluByU
dont forget another 500-700 for a tune and the labor for installation.. plus the misc goodies like fluids, belts, plugs, etc..etc..
Also dont forget as your increase power items downstream (driveline) become less reliable because they are not designed to withstand those loads.. be prepared to upgrade the read end/trans axle, half shafts, clutch, transmisssion, etc..etc..
I've been down that path with many cars.. its fun.. but costs lots more than you think.. there is a reason there are so many modified cars in teh for sale sections..
However.. no doubt it'll be fun,fun,fun!
Old Nov 9, 2008 | 09:56 AM
OKsweetrides's Avatar
OKsweetrides
you don't gotta drag the idea of it.
Plenty of cars are living with more hp than that on otherwise stock cars with very few other mods. Clutch is a given though.
It's a lsx for pete's sake. I personally don't know of any that haven't been highly modified.
Old Nov 9, 2008 | 11:11 AM
Z06_BluByU's Avatar
Z06_BluByU
Not knocking the idea.. just setting a picture of what my past experiance with a few of my other cars has been.. Its good to know what you're getting in to before you are there..
As for an LSx not modified.. now you know at least one!
Old Nov 9, 2008 | 01:50 PM
zeevette's Avatar
zeevette
Talk to one of the vendors here about a head/cam combo featuring the TFS heads. You'll get a proven system, and great customer service. I would recommend ECS, or Vengeance, among others who do TFS combos. Maybe even get a better price? I bought my TFS heads directly from the company that does the machine work on ALL the Trickflow LS heads, TEA. They gave me great service, and also custom port work above and beyond the CNC program. I would definitely have the heads milled for more compression. BTW, the above naysayer is right; you have to make other, costly mods to accomodate your added power. You just have to decide if it's worth it. Your S/O may not be too happy about the stink, shake, rattle and roll.
Old Nov 9, 2008 | 02:09 PM
427CPE's Avatar
427CPE
I haven't checked lately, but for the TFS 215c heads, there are 2
different ones.
1-As Cast
2-CNC Ported by TEA http://www.totalengineairflow.com
You want #2. They cost about $2,395. FYI, the heads sell as 215s, but are really 219s. For the price summit is offering, that is not bad. I would be curious which RR they are including. I used the Harland Sharps, though no real opinion there. One significant factor is TEA will deck the heads at no charge. You do not want to install a 64cc head on an normally aspirated engine. You want 59 to 61cc chambers for good compression and power. I think the 61cc I had resulted in around 220psi static cranking compression and I'm guessing 11.25+:1 CR.
I have used both the 215 TEA CNC head on 346 and now have TFS 235s on my 402. They produce good power.
Old Nov 10, 2008 | 09:36 PM
Ron@Vengeance Racing's Avatar
0Ron@Vengeance Racing
Former Vendor
FWIW
Vengeance Racing Heads/Cam Package buit to YOUR SPECS!!!
TrickFlow 220cc "As Cast" 3.90" OR 4.0" Bore Cylinder Heads
Milling of Cylinder Heads to Desired Compression
TrickFlow 7.500 Hardened Pushrods
Vengeance Racing VRX Series Camshaft-YOUR CHOICE
Yella Terra Ultra Lite Roller Rockers
GM MLS Head Gaskets
ARP Head Bolts
GM Front Cover Gasket
GM Front Cover Seal
GM Waterpump Gaskets
FAST Intake Replacement Gaskets
NGK TR55 Plugs x 8
2899.99 plus shipping!!!!
**Upgrade to CNC 215 or 225 TrickFlows for 679.00
**Add Melling Hi Volume Oil Pump for 139.00
**Add LS2 Timing Chain for 39.99
**Add Ported 92mm FAST Intake for 1029.00
**Add either a Ported LS2 90mm TB/Nick Williams 92mm TB/FAST 92mm TB for 369.00
TrickFlow Cylinder Heads power some of the quickest/fastest LSX combos in the country!!! Offering 13.5* Valve Angles over the standard 15* LS1 Valve Angle for increased mid lift flow AND increased piston to valve clearance!! Thicker Rockers Bosses/Extremely thick deck surfaces are two other advantages to this incredible aftermarket casting!!!
Vengeance Racing VRX Series camshafts have proven themselves time and time again to not only lay down the # on the dyno but to perform just as well on the street AND at the track. If you need help selecting a camshaft feel free to call/email/PM. We will spec a cam to suit your needs.
To Trick Flow Top End
