Burned C5 frame question?
Old Nov 8, 2008 | 10:00 PM
NVTHIS's Avatar
NVTHIS
From: Piedmont, SC Currently Own: 99 Nassau blue FRC. Previously Owned: 84,95,98 Indy Pace,01 Z06
Default Burned C5 frame question?
Hey guys, I am working on a Z06 project and I am needing to section some front frame rails. I have found a C5 frame that is pretty much perfect, except it was involved in a fire. I really am not sure where the fire started (engine or cabin area), but the car is pretty much burned down to the frame. What I am wondering, is whether or not the fire weakened the frame? I was told I can pretty much have the car, but was wondering if it would be worth the hassle.
Old Nov 8, 2008 | 10:15 PM
kingsey's Avatar
kingsey
Run dont walk away
C5s are cheep enough you should be able to find non burned to a crisp parts
Old Nov 9, 2008 | 09:59 AM
killain's Avatar
killain
Oldtimer
Originally Posted by kingsey
Run dont walk away
100% Since you have no idea of the nature of the fire, you also don't know how hot it got and what effect it would have on the molecular structure of the metal. Me, I wouldn't take a chance. . . . Yes, I am a welder by trade.
Old Nov 9, 2008 | 11:04 AM
PuddleJumper's Avatar
PuddleJumper
um if it was an gasoline fire witch is probaly what it was id say only do it if your going to put it in an show room for show only
if your going to drive it
um as i have been told just go find one
there out there anywhere from 10,000-35,000
just depends on where there from who owns them and how bad they want to sell
go on eBay motors an have an look you will get an idia what the going rate is
anyway my $.02
Old Nov 9, 2008 | 11:39 AM
Mike McCoy's Avatar
Mike McCoy
I'm not an engineer, but I would think that the C-5 Corvette frame may be tempered steel. If it is, a fire will destroy it's strength.
Old Nov 9, 2008 | 02:33 PM
Bill Dearborn's Avatar
Bill Dearborn
The side rails of the C5 frame were made by taking a tubular piece of steel and hydroforming it into the rectangular/bent piece that goes from the front frame crossmember to the rear frame crossmember. Doubt that it is tempered.
Bill
Old Nov 9, 2008 | 03:18 PM
NVTHIS's Avatar
NVTHIS
anyway my $.02
Thanks guys from the comments! All I am wanting out of this car is the front frame rails or front frame section from cowl forward. I definately would not try to repair this car as there is literally nothing left except the frame, crossmember, torque tube, etc. I am just needing a front clip for my Z06 and since I had easy access to it, I thought I would see what you guys thought about it. Yeah, I can buy a complete front clip for $3k-$4k but finding it in the right color and then maybe still having to paint, I'm just seeing what my options are. I know going with a complete front clip would be the best way!
Old Nov 9, 2008 | 11:45 PM
cebars's Avatar
cebars
http://forums.corvetteforum.com/c5-p...post1567740073
BARE CHASSIS----2500.00 Keep in mind, this is a pick up item only, so if your near to New York, Let me know with a pm
Old Nov 10, 2008 | 12:11 AM
mrgil's Avatar
mrgil
Burnout
Default Frame
The frame is hydroformed, that means it is cold worked to shape using water as a hydraulic fluid. while it is not quenched and tempered my guess would be there is some cold working gone on and it will be harder than unworked steel, I would stay away from a burned frame.
jmho
mrgil
Old Nov 10, 2008 | 06:26 PM
NVTHIS's Avatar
NVTHIS
Thanks guys, my initial thoughts was to just let this one pass. But for someone pretty much willing to give it to you, I had to ask. Anybody local to SC who may have a front frame section, just let me know.
To Burned C5 frame question?
