Seafoam!!!
Old Nov 10, 2008 | 06:22 PM
JDaniel's Avatar
JDaniel
St. Jude Donor '08-'09
Thanks a lot for all the replies, fellows. Seems as though a lot more were interested in this than just I. Im going to find a brake vacuum line tomorrow and do it. Feel free to add on any other info if you find anything different. I will report back tomorrow and let you guys know how it went. Thanks again!
Daniel
Old Nov 10, 2008 | 06:25 PM
Evolution's Avatar
Evolution
Originally Posted by sneakelman
Use the brake vacuum line. Put a smaller hose in the can, then run that hose into the brake line. Go slow. Suck up about half a can. Then dump then other half in the fuel tank.
Take her out and run her for a bit after that.
Have you actually done this? Cause that is sucking up fluid without atomizing it. If you put this into the induction system, you need some form of spraying unit. Not just pooring half the can down into the motor.
I also can't see, even IF that worked how it could evenly distribute to all cylinders.
There is no way I'd risk hydrolocking my motor this way. Would you do this with gas too?
Old Nov 10, 2008 | 06:42 PM
TWOBUELLS's Avatar
TWOBUELLS
I spent an entire day down at the beach trying to get this stuff into a can. How in the hell do you get it into the motor ?
Old Nov 10, 2008 | 07:25 PM
Ryan040675's Avatar
Ryan040675
The big benefit to sucking it in through a vacuum line is that it cleans out the oily residue left in the intake from the pcv valve. They also make a version called "deep creep" which is supposed to be sprayed up into the intake and around the throttle body. It smokes you out of the neighborhood when you are done though. It certainly can't be great on the plugs either so you'd probably want to do this sometime shortly before a scheduled plug change.
Old Nov 10, 2008 | 07:29 PM
dobewillie's Avatar
dobewillie
good posts thanks I learned a little
Old Nov 10, 2008 | 08:04 PM
JDaniel's Avatar
JDaniel
HAHA!! Funny stuff there!
Old Nov 10, 2008 | 08:55 PM
diyguy's Avatar
diyguy
I've not done it on my C5 but my kids and his buddies have all done it.
The smoke is incredible....Warn your neighbors that you are NOT on fire.
Not a C5, but here's a typical example
Old Nov 10, 2008 | 09:14 PM
rudolph schenker's Avatar
rudolph schenker
Originally Posted by AlexSmith
Autozone, O'Reilly's, Advance Auto etc.
-Alex
Thanks!!
Old Jun 17, 2009 | 02:58 PM
Bigcountry7's Avatar
Bigcountry7
So is ther a consensus on where to put this stuff to clean the cylinder heads? I have used it in the fuel tank before but never for this purpose. I have read alot of good things about seafoam used this way and want to do it. But, where specifically do I put it? Is it bad for the plugs and should I spray it in? Not sure how I would go about spraying it in.
Old Jun 17, 2009 | 03:14 PM
JDaniel's Avatar
JDaniel
Ok... I did it myself and it works great. I didnt "hydrolock" my motor nor did it do any damage to it in any other way.
Just look at the brake booster from the drivers side of the car. On the left hand side of it (as you are looking down at it) there will be a large vacuum line. Take a pair of needle nose pliers or small channel locks and loosen the band that holds the rubber vacuum line to the booster. Then grab the line and pull it off... if it doesnt come off with the band. Then (what I did) was took a funnel and put the end of it in the tube. I had a friend crank the car and let it warm up then I dumped the can into the funnel. The car will start to bog down. Just turn the key off at this point and let the Seafoam sit in there for about 30 minutes to 1 hour. Then start the car. This may take a couple of times to do so but it will finally start. Then just watch the smoak show.
The smoke is all the oil from your intake and carbon build up on your pistons burning away.
Old Jun 17, 2009 | 03:22 PM
gdev_'s Avatar
gdev_
It's printed right on the can, if I remember correctly.
Old Jun 17, 2009 | 04:21 PM
teebee's Avatar
teebee
2021 C6 of the Year Winner - Unmodified
Originally Posted by bucwheat
This stuff is great,After a year of dealing with a dead gauge and trying the Techron with no results,I broke down and tried Seafoam,after 1 can it worked partime after the second can ,It's working great ,all the time.
My gauge wasn't completely dead, just died at a 3/8 tank. I put a whole can of Seafoam in and let it soak for a week or so. Fixed it right up. I was afraid I'd have to pull the pump and sending unit out...like I did my pick-up. I'm now going to run a can through my car and the pickup too, just for good measure.
I forgot,I let the car sit for a week with the Seafoam in the tank,don't know if that helped but I figured the longer that the sending units soaked in seafoam the better.
Yea, I let it soak good, and it seemed to do the trick.
Originally Posted by rudolph schenker
Where is a good place to get Seafoam?
We can buy it at our local Wally-World.
Old Jun 17, 2009 | 04:25 PM
  #33
rebelheart's Avatar
rebelheart
Alex,we have a pile of factory TSB's dealing with valve and cylinder heads carboning up,so yes indeed they still do it!
Old Jun 17, 2009 | 05:00 PM
  #34
philadd's Avatar
philadd
I've been using Seafoam on my cars for years. I typically use 1/3 of a can through the brake booster vacuum line, and then I pour the last 2/3 of a can in the gas tank.
Just do a search for seafoam videos. Doesn't matter what kind of car. I know there's got to be 100+ seafoam videos on YouTube, with a bunch of them showing how they used it.
Old Jun 17, 2009 | 05:23 PM
  #35
~Josh's Avatar
~Josh
Banned Scam/Spammer
Pour it into the vaccum line SLOWLY.
Don't just dump it in.
Old Jun 18, 2009 | 04:01 PM
  #36
JDaniel's Avatar
JDaniel
Nah. I just dump it and let the car almost die and then let it sit. LOL Seriously.
