Seafoam!!!
Old Nov 10, 2008 | 07:23 AM
JDaniel's Avatar
JDaniel
St. Jude Donor '08-'09
Default Seafoam!!!
I changed out the fuel filter on my diesel truck and treated it with Seafoam and it did a great job and now im wanting to do the Corvette. Im looking for a vacuum line that I can disconnect and put into the can and then start the car. Can anyone give me a descriptive location on where I may find a good vacuum line to use or even post some pics of how they previously completed such a task? Any help would be great! Thanks!
Daniel
Old Nov 10, 2008 | 08:03 AM
DropTheTop's Avatar
DropTheTop
I just added it into a full tank of gas, and my erratic gas gauge works great now. Sorry I can't help with the vacuum line.
Old Nov 10, 2008 | 09:07 AM
bucwheat's Avatar
bucwheat
This stuff is great,After a year of dealing with a dead gauge and trying the Techron with no results,I broke down and tried Seafoam,after 1 can it worked partime after the second can ,It's working great ,all the time.
Old Nov 10, 2008 | 09:32 AM
Dominic Toretto's Avatar
Dominic Toretto
What size can did you use, or do they come in different sizes, I don't remember?
-Alex
Old Nov 10, 2008 | 09:47 AM
Evolution's Avatar
Evolution
It only comes in one size can, that I've seen. You can use a sprayer to inject it after the Maf. Or just put a can or two in the tank. I'm picking up a daily driver C5 this weekend and when I get it back home, I'm putting one can in the tank, and spraying one into the induction to clean the TB and intake. Hope this helps.
Note: When you spray a can into the induction, do a little at a time and expect a cloud out of the exhaust.
Old Nov 10, 2008 | 09:50 AM
bucwheat's Avatar
bucwheat
I put a can in a half tank of fuel.
Old Nov 10, 2008 | 09:52 AM
bucwheat's Avatar
bucwheat
I forgot,I let the car sit for a week with the Seafoam in the tank,don't know if that helped but I figured the longer that the sending units soaked in seafoam the better.
Old Nov 10, 2008 | 11:33 AM
rudolph schenker's Avatar
rudolph schenker
Where is a good place to get Seafoam?
Old Nov 10, 2008 | 11:43 AM
DropTheTop's Avatar
DropTheTop
AutoZone, SchlepBoys, etc...
Old Nov 10, 2008 | 11:48 AM
Dominic Toretto
Autozone, O'Reilly's, Advance Auto etc.
-Alex
Old Nov 10, 2008 | 11:58 AM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
I use Seafoam in everything we own, Vettes, Nissans, snowblower, lawn equipment, you name it. I've started the snowblower (before I started using Seafoam) and it ran like crap, and had no power (stale gas!) didn't drain the tank, but just added Seafoam to the tank, and after a few minutes all was good again (other than having to remove the freakin' snow!) After buying it in the 16 oz (or whatever they are) cans and keeping them for proper measure I buy it in the gallon can for just over $40 and refill the smaller cans. I've never used it in anything but the "tanks" but stand fast to it's effectiveness, and forget the Stabil, Seafoam has fuel stabilizers in it as well as the detergents we all use it for in here.
Old Nov 10, 2008 | 12:11 PM
oh1vette's Avatar
oh1vette
do a search on seafoam, this link a guy says he put it thru the brake vacuum line.
http://forums.corvetteforum.com/c4-g...e-but-wow.html
Old Nov 10, 2008 | 12:17 PM
oh1vette's Avatar
oh1vette
here's a better link:
http://forums.corvetteforum.com/c4-g...ea-foam-2.html
Old Nov 10, 2008 | 01:33 PM
tracks03's Avatar
tracks03
My '03 has about 35k on it, and I'm thinking of doing this. So is there really any advantage to either running through the tank or the vacuum line?
Old Nov 10, 2008 | 01:39 PM
Dominic Toretto
Different systems, different outcomes.
-Alex
Old Nov 10, 2008 | 02:03 PM
C5Vette168's Avatar
C5Vette168
St. Jude Donor '08
I have a can of this stuff sitting around. I bought it a couple of years ago. I am going to try on my van first to see what the results are.
Old Nov 10, 2008 | 02:17 PM
tracks03's Avatar
tracks03
-Alex
Like what? I guess I don't understand, wouldn't running through the fuel tank first clean everything? What does running through the vacuum line do differently?
To Seafoam!!!
Old Nov 10, 2008 | 03:12 PM
10U 99's Avatar
10U 99
a higher concentration
I've had better luck correcting the fuel gauge thing with seafoam than techron
Old Nov 10, 2008 | 03:19 PM
sneakelman's Avatar
sneakelman
Use the brake vacuum line. Put a smaller hose in the can, then run that hose into the brake line. Go slow. Suck up about half a can. Then dump then other half in the fuel tank.
Take her out and run her for a bit after that.
Old Nov 10, 2008 | 03:33 PM
Dominic Toretto
Using it in the fuel system will clean out the those components. People run it through the vacuum lines of the engine to clean any carbon buildup in the cylinder heads. I have not personally done that, but heard that is very good for the engine. I have also heard that it is not as necessary to do that as much these days due to fuel being more refined and cleaner.
-Alex
