156,000 miles
I have had the electronic climate control out 2 times to re-solder internal failed solder joints, and now have bulbs burning out in the radio to deal with.
So far no issues with major electrical items like alternator or starter, just a lot of fairly expensive small electronic/electric item failures and bad/corroded ground terminations. The engine/drive line seem OK....at least it will be OK until something breaks!
Jennifer
The top has a few wear spots, but still surviving after all these miles.
I am the second owner. The engine, A4 tranny and 2:73 diff are stock. CAI and Bullits, stock tune. On 10-18-08 the vette pulled 317.04 rwhp and 320.22 tq. A previous run a few days earlier showed 305.02 rwhp and 310.14 Tq. the humidity setting was wrong on the dyno that day, hence the lower numbers.
Try to get some background on the Vette, if there is a solid history behind it that is a plus, if not... ya roll the dice....
JB.
Those miles could be fine and the car could be alright, but those are too many miles to gamble. There are plenty of C5s out there and newer C5s are only getting cheaper. Fools rush in, don't let emotion get the best of you.
-Alex
I would honestly keep looking for a vette with lower miles. If you are still not convinced I will loan you mine for a week and that should change your mind.
So, as other's have said, you can find a car with less miles for the proper amount of money. If if know for sure how this car has been taken care of, then its your choice. I wouldn't have tried to sell mine as no one in their right mind, not knowing me, would buy my car. My son knows how well I've taken care of it therefore its his now and if it became a money-pit for him, he said he'll give it back to me and I'll make sure its perfect. BTW, its stock all the way, well it is for now...lol. Its due for the bottom end to be opened up, new bearings and so on.
If the car has been well cared for and serviced.Then i would GO for it. Its a LS1 you take good care of a car like this. I have seen them run just fine with no problems. And thay have 200K on them..If they took good care of it i would do it..So find that out first then BUY!!
Btw, for what its worth i was at a dealership this weekend in FL and my 134k car booked at right about 7k using their NADA book.
