Security
Old Nov 11, 2008 | 05:28 PM
TonyL's Avatar
TonyL
Default Security
The security light came on yesterday and stayed on . Any ideas what is going on and what I need to do to take it off.
Old Nov 11, 2008 | 06:38 PM
Not A Z06's Avatar
Not A Z06
When mine did it all I did was clean the chip on the key and it went out.Has not come back on since.
Old Nov 11, 2008 | 06:49 PM
Z28Johnny's Avatar
Z28Johnny
Originally Posted by Chuck A
OK i have a question why does it always go into AC mode when i try to turn on the fan for either heat or just outside air, is that normal? sorry to hijack, hope you dont mind
Sometimes I understand hijacking if it has something to do with the existing thread, but your question has nothing to do with security.
Old Nov 11, 2008 | 06:53 PM
Chuck A's Avatar
Chuck A
St. Jude Donor '08-'09
I understand i will remove it, but didnt really want to start a new thread for an answer that would be answered quick, sorry
Old Nov 11, 2008 | 06:54 PM
Oldvetter's Avatar
Oldvetter
This was from left field, start a new thread.
As to original poster, try cleaning key with alcohol. If this doesnt work, try cleaning grounds (see Bill Curlees post). Also try pulling up your codes.
Old Nov 12, 2008 | 12:19 AM
Wiked99's Avatar
Wiked99
Had that problem for about a year plus other gremlins....I replaced the battery and it went away.
Old Nov 12, 2008 | 10:25 AM
poolboy's Avatar
poolboy
I would suggest piulling the diagnostic codes to see if any are being posted - if so the codes should help you isolate the problem...
That would be a good first step. Hope that's all it takes.
Old Nov 12, 2008 | 11:07 AM
Bluefire's Avatar
Bluefire
True Dat!
Old Nov 12, 2008 | 01:04 PM
TonyL's Avatar
TonyL
Well I cleaned both of my keys. Security still stays on.
Pulled codes had several with past ABS problems that ended in H. Had one that had 40 BCM B2723 HC.
I tried reset. Security still on.
Any more ideas?
Old Nov 13, 2008 | 08:17 AM
poolboy's Avatar
poolboy
Any more ideas?
From posts I've seen in the past, if the security light is on and there are no codes, I think it has been either the keys or the ignition switch. Since you've tried both keys, chances are they are not the cause. You may want to pm Bill Curlee to see if he has any thoughts.
Old Nov 13, 2008 | 10:35 AM
TonyL's Avatar
TonyL
Thanks, i'll pm Bill.
To Security
