Lets hear from the 2002s
Old Nov 12, 2008 | 08:41 PM
vet02's Avatar
vet02
I have a 2002 Coupe I bought new. It has close to 120k on it. Aside from normal maintenance items (brakes, tires, etc), I had to replace the EBCM, headlight gears, and resv tank. Otherwise it's held up well. It's important to note I also have Kooks headers, high flow cats, Corsa exhaust and 4.10 gears. All mods were done at around 50k so they have also held up very well. I'd have to say I've been happy with the durability of the car.
Old Nov 12, 2008 | 08:43 PM
Mile High C5's Avatar
Mile High C5
Originally Posted by VetteDriven
So how are the 2002 Corvettes holding up?
Any repairs or major issues?
Nothing wrong so far. Only 25K miles and not my daily driver, but absolutely nothing has gone wrong with it to date.
Old Nov 12, 2008 | 08:54 PM
VeroWing's Avatar
VeroWing
I've had an '02 Quicksilver coupe for a few months and a few thousand miles with no problems as of yet. It has 36,000 miles, and I love it.
Old Nov 12, 2008 | 08:57 PM
JimZRyd's Avatar
JimZRyd
St. Jude Donor '12
My 02 Vert has 21K miles on her with no major issues. Drivers side window/door lock sticks on occasion but thats it. Only scratches on it are from the previous slack owner. Not a DD though.
Old Nov 12, 2008 | 08:58 PM
jzemo's Avatar
jzemo
the white 02 had no issues
the blue (current) 02 had a problem with the EBCM
Old Nov 12, 2008 | 09:04 PM
stormrider's Avatar
stormrider
74K only problems so far (knock on wood) had to replace the starter, steering wheel sensor and radiator (radiator was my fault)
Old Nov 12, 2008 | 09:08 PM
widewheel's Avatar
widewheel
Let's see, where to begin? Bought the car used three years ago this month. It's an A4 vert. In order of occurance: replaced tires, HVAC display repair, new accessory belt tensioner, new battery, new transmission at 87,000 miles, EBCM repaired, new oil pressure sender, tires again and 4 wheel alignment, new water pump, new belts & hoses, left rear CV boot (replaced whole assembly). Just got back from a trip to Kansas Saturday (550 mile round trip) and car rolled over 92,500 miles. Will be doing plugs/wires soon. Sometimes memory mirrors go nuts and I have to readjust. Finding non ethinol tainted fuel here in Oklahoma is getting easier. Three stations here in town now as opposed to only one three months ago. Thought something was wrong when it started getting only 26.5 mpg until I discovered they were passing ethinol off as real gas. It's back to 28.5 mpg with the real stuff. Still get that feeling when I crank up the engine and go. Especially when the weathers good and I put the top down. My only question is "how do some of you drive your cars so little"?
Old Nov 12, 2008 | 09:24 PM
zeevette's Avatar
zeevette
'02 ZO6, with 15k miles. It has a leaking diff, and sticking clutch. Terrible money pit, thanks to endless modding, Absolutely love this car. Best high performance car ever.
Old Nov 12, 2008 | 09:31 PM
Plasticfan's Avatar
Plasticfan
02 Coupe, 81k. Bought it in Jun 07. Replaced starter, that's it. One of the most maintenance free cars I've ever owned.
I'm gonna drive it till the wheels fall off.
Old Nov 12, 2008 | 10:03 PM
flyzlow's Avatar
flyzlow
My rear hatch has the dreaded paint bubbling syndrome. There are several threads, including mine, about this problem. I am working with a dealer and GM to get it replaced at no charge...it is a $1400 repair otherwise. My right door lock failed at 9K miles and was repaired out of warranty as a "Dealer courtesy"
Old Nov 12, 2008 | 10:04 PM
blue63cpe's Avatar
blue63cpe
02 Z06, 33,xxxk. Replaced delco battery in 07,cracked the reflector on drivers door, need to fix rocking drivers seat. Its toy #2 with the 63 being toy#1 and I don't own a trailer.
Old Nov 12, 2008 | 10:23 PM
lil vette's Avatar
lil vette
Purshased mine almost 2 years ago.
Did the HVAC dim light fix, that's about it.
The rest were mods...the normal stuff.
Old Nov 12, 2008 | 10:26 PM
  #33
cdnguyred88's Avatar
cdnguyred88
Bought mine on Nov. 1, drove almost 1,500 kms since then, first owner never had any problems at all. Triple Black Vert
Old Nov 12, 2008 | 10:45 PM
  #34
doug doo wop's Avatar
doug doo wop
bought mine new in Oct. '01 and replaced battery twice and the usual leaking left rearend(warranty), that's it, great car!
Old Nov 12, 2008 | 11:08 PM
  #35
Jacks02's Avatar
Jacks02
Bought my white coupe 25 months ago -- with 11K miles. Zero issues. Now has 20K miles and recently clocked 31.6mpg highway. Stock, auto, love it!
Old Nov 13, 2008 | 12:21 AM
  #36
2L8ULUZ's Avatar
2L8ULUZ
Bought March 2008 from the original owner with 28,000 miles. Column lock recall, replaced original battery and repaired a non working power door lock and thats it since it was new. I'm watching for the left rear axle leak that I understand is inevitable. I love this car.
Old Nov 13, 2008 | 12:57 AM
  #37
versatile's Avatar
versatile
Originally Posted by tricep
2002 Z06 with 30K-- so far, only this:
and it was covered under warranty. Fixed in less than 2 hours.
2002 vert 20,000 miles....same issue!
To Lets hear from the 2002s
Old Nov 13, 2008 | 01:38 AM
  #38
Z06ster's Avatar
Z06ster
'02 Z here with 45K on the clock. OK, here we go:
1. Rear Differential leak - to be expected. Repaired by Forum members razor2430 and gairno.
2. HVAC actuator door failure - repaired by dealer
3. Gas sending units failure (both tanks) - sadly to be expected, repaired by dealer... now I have accurate gas gauges again!!
4. HVAC blower stopped - corroded connector - repaired by me
5. Door lock problem - famous bakersfield thread - repaired by me thanks to bakersfield
6. Driver side door panel complete loss of power - fixed by me thanks to helpful forum members!
Despite these issues, I love this car and I am totally obsessed with it. Car is currently out getting facelift. Comes back this Saturday,
Old Nov 13, 2008 | 01:46 AM
  #39
DeeGee's Avatar
DeeGee
I had many of the common problems early on:
Diff seal leak, headlight gear change, EBCM change, door lock control module bad, dead battery. Apart from the battery mostly fixed under warranty.
For the last 2 years its been nearly perfect apart from a nuisance active handling problem (I need to replace the SWPS).
Overall not bad at all especially for a high performance sports car.
Old Nov 13, 2008 | 01:51 AM
  #40
Mariamznm's Avatar
Mariamznm
I had an 02 before I mad the awful mistake of trading it in for a C6. Anyways when I traded it in it had 75xxx miles on it. Even at those miles the car was strong. Only issues was the headlight motor and the ac bulb went dim. Strong car!!
