battery
Old Nov 14, 2008 | 10:40 AM
mooty1's Avatar
mooty1
Default battery
do you have to do anything special to disconect the battery and then hook it back up? almost afraid to touch anything!
Old Nov 14, 2008 | 11:25 AM
Mike McCoy's Avatar
Mike McCoy
With the key in the off position, just remove the negative cable from the battery first. You won't hurt anything, but you will lose the radio programing code. To reconnect it, start with the positive cable.
Old Nov 14, 2008 | 11:28 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Always remove the negative (black) terminal FIRST, when disconnecting the battery.
When reconnecting, always connect the negative terminal LAST.
Old Nov 14, 2008 | 11:54 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
This is true anytime with any car - not just a Vette.
Old Nov 14, 2008 | 12:33 PM
hotwheels57's Avatar
hotwheels57
...unless it's a positive ground. That's probably way before most here were even born ('50s and earlier cars/tractors), but they're still some out there.
Old Nov 14, 2008 | 05:39 PM
If you have the TheftLoc feature enabled, you will need the four digit code to get the radio working again.
Old Nov 14, 2008 | 05:52 PM
rws.1's Avatar
rws.1
nothing different....
Old Nov 14, 2008 | 09:36 PM
Cosmic Charlie's Avatar
Cosmic Charlie
I just replaced my battery and did this>
Disconnect the positive first
then the negative next.
And re-connected the negative first
then re-connect the positive.
and everything is OK. (ALTHOUGH I DID IT WRONG)
so I lucked out ? *hey, I didn;t know !
does the owners manual say how ?
and WHY ? the special order ?
Old Nov 14, 2008 | 09:42 PM
jraschke11's Avatar
jraschke11
St. Jude Donor '08-'09-'10-'11-'12-'13-'14
The special order has to do with the laws of electricity and grounding. If you don't disconnect the ground first you could easily send sparks a flyin and someone could get hurt.
Old Nov 14, 2008 | 09:51 PM
rickko's Avatar
rickko
If you disconnect the positive cable first its most likely you'll create a spark. Same thing if you reconnect positive last. It most likely will spark.
Normally the spark won't cause any problems but, if there is gas fumes or the battery is leaking, you could be surprised finding yourself waking up in a hospital after the explosion.
I've seen and heard one battery explode. It was HUGE! Sounded like a grenade going off. You don't want to risk that by sparking the positive cable/post.
..rickko..
PS. Electrocution is not at issue.
Old Nov 14, 2008 | 09:53 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
The first time you are disconnecting the positive side first and your wrench or ratchet lays up on a metal part of the car you'll understand.
You'll think the 4th of July came early.
Since newer cars have a very large percentage of plastic under the hood it's not as bad as it was on older older cars. Still a good idea though.
Old Nov 15, 2008 | 10:41 AM
Cosmic Charlie
thre rule is
Negative First, Then Negative Last
got to remember that ! SOMEHOW !
Old Nov 15, 2008 | 03:20 PM
Quicksilver Vert 01
Originally Posted by Cosmic Charlie
thre rule is
You got it!
Old Nov 15, 2008 | 05:52 PM
The NNIAL8R's Avatar
The NNIAL8R
St. Jude Donor '11,'13
"I voluntarily took 60 days off from OT"
and THAT my friends is the REAL reason you disconnect the negative terminal first....
Old Nov 15, 2008 | 06:15 PM
Blue 92's Avatar
Blue 92
Isn't it amazing how much sparks that can throw.
And oh yea, I've done it before.
Old Nov 15, 2008 | 06:19 PM
The NNIAL8R
Yup, I blew up a battery doing that on an AMC Pacer on Superbowl Sunday, 1977...(Broncos were playing)...I remember it WELL!!!!...It knocked BOTH lenses out of my eyeglasses....Ive never made that mistake again
Old Nov 15, 2008 | 09:24 PM
Dominic Toretto's Avatar
Dominic Toretto
thre rule is
-Alex
Old Nov 16, 2008 | 12:14 AM
TheDVS1's Avatar
TheDVS1
Blew up the battery just by turning the key and attempting to start my '84 VW GTI about 20 years ago. I thought someone was gunnin' for me! It blew the hood up about an inch releasing the safety latch and leaving a nice dent in there as well. Battery acid all over the place, broke the cable release too. What a joyful experience!!
Regarding the battery cable removal sequence, I once welded my wrench to a brake line trying to disconnect the positive cable first. It burned right thru the line starting the brake fluid on fire. Blew it out quickly tho.
You knew auto batteries made great welders, didn't ya'??
To battery
