Size matters????? Need help.
Old Nov 14, 2008 | 01:32 PM
whitelite's Avatar
whitelite
Default Size matters????? Need help.
Ok, back on task you folks.......
GOAL: Fill wheelwells better.
PROBLEM: My 2k Vert has Aci front spoiler so I can't lower it without more spoiler scrapage....lol
SOLUTION: Maybe a 1-2" larger overall diameter tire/ wheel setup, then lower 1" so the front spoiler clearance doesn't change.
THANKS FOR ANY INPUT, Randy
Old Nov 14, 2008 | 01:39 PM
damilleniumboy's Avatar
damilleniumboy
What wheels and tires are you currently running?
Old Nov 14, 2008 | 01:43 PM
Dominic Toretto's Avatar
Dominic Toretto
What he said.
-Alex
Old Nov 14, 2008 | 02:24 PM
whitelite's Avatar
whitelite
Stock thin spokes and stock size Khumos. It seems like most oversized setups run shorter sidewall tires so overall diameter doesn't change and traction/ ride could suffer.
Old Nov 14, 2008 | 03:57 PM
Dominic Toretto
Exactly, only so much wheel can fit under the wheel-well before rubbing and such becomes an issue. So bigger wheels will almost definitely need a shorter sidewall. So to fill the gaps you will need to lower the vehicle.
-Alex
Old Nov 14, 2008 | 03:58 PM
Independent1's Avatar
Independent1
St. Jude Donor '08
Maybe try C6 size rims and tires?
Specs below.
Wheel size:
front: 18 inch x 8.5 inch
rear: 19 inch x 10 inch
Tires:
Goodyear Eagle F1 Supercar (w/Z51)
Extended Mobility
front: P245/40ZR18
rear: P285/35ZR19
Old Nov 14, 2008 | 04:29 PM
whitelite's Avatar
whitelite
-Alex
How much wheel is too much? Can't lower the vehicle...see original post!!!!
Specs below.
Wheel size:
Tires:
Extended Mobility
front: P245/40ZR18
rear: P285/35ZR19
Have you done these sizes? Can't afford trial and error.
I think we should be able to at least go 1-2" larger overall diameter without rubbing. That would set my car up 1/2-1" and then I could lower it by that much without changing the ACI spoiler ground clearance
Old Nov 14, 2008 | 06:29 PM
Independent1
St. Jude Donor '08
^No. My car is in my avatar. More interested in performance than looks, not that I don't care how my car looks.:o
You can do a little bit of research by going to tire rack and looking up the tire sizes specs and then doing some measurements on your car, or
try finding someone with C6 size tires and try putting them on your car.
Old Nov 14, 2008 | 06:45 PM
JPM@AutoBuffs's Avatar
0JPM@AutoBuffs
Former Vendor
From: The AutoBuffs Army is unmatched in the Custom world! www.autobuffs.net
S. Jersey Events Coordinator
St. Jude Donor '08-'09-'10
Cruise-In IX Veteran
I would do the following...
Front 19 x 9.5
Rear 20 x 11
John@autobuffs.net
Auto Buffs LLC.
2 Kerry Ct,; Suite E
Southampton, NJ 08088
609-859-0900
www.autobuffs.net
Authorized IFORGED Dealer
Authorized East Coast Supercharging Dealer
Authorized TireRack Dealer
Custom Painting & Airbrushing
Pinstriping
Custom Detailing
Car Audio
Mobile Electronics & Video
Remote Car Starters / Alarms
Old Nov 14, 2008 | 07:17 PM
whitelite's Avatar
whitelite
[QUOTE=J.P.M.;1567849905]I would do the following...
Front 19 x 9.5
Rear 20 x 11
With what tires? What would my final diameter be compared to stock? Anyone I've read about doing 19/20 combo goes with a such a lo-pro tire that the overall diameter stays the same but the ride gets harsher.
Old Nov 14, 2008 | 07:36 PM
0JPM@AutoBuffs
Former Vendor
[QUOTE=whitelite;1567850246]
Front 19 x 9.5
Rear 20 x 11
I run the above sizes on one of my cars and use the below tire sizes.
Front: 265 / 30 / zr19
Rear: 305 / 25 / zr20
I dont have a ride difference in regards to harshness at all.
There will be no effect on the speedo either.
John@autobuffs.net
Auto Buffs LLC.
609-859-0900
www.autobuffs.net
Pinstriping
Custom Detailing
Car Audio
Old Nov 14, 2008 | 08:16 PM
whitelite's Avatar
whitelite
That leaves the tire diameter the same so I have gained nothing. I still have a large gap in the wheelwell.
Old Nov 14, 2008 | 08:30 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Ground clearance is overrated.
To Size matters????? Need help.
