C5..Ac question,!!! help
flake ** button the light and air comes on for about 6 seconds and the light and air turns off!!!?? any one now what's going on.
i do also have some burned out lights on the climate control,that is a common thing on the C5's.
thanks peterhttps://www.corvetteforum.com/forums/images/smilies/willy_nilly.gif
The dim lights in the climate control panel is a common problem. If you do a search there are ways to fix it, if you can use a screwdriver and a soldering gun.
Good luck
From the owner manual
The air conditioning does not operate at temperatures below approximately 35F to 40F (2C to 4C). The light on the A/C button will flash if pressed when air conditioning is not available.
