Cd changer!!!!!????
Old Nov 21, 2008 | 08:48 PM
Vettelover1990's Avatar
Vettelover1990
Default Cd changer!!!!!????
Ive herad the C5 has the cables run already to install and simply plug in a cd changer. My question is does anyone have the diagram or describe where the cables are...?>
Old Nov 21, 2008 | 09:29 PM
Black_6-Speed's Avatar
Black_6-Speed
Old Nov 21, 2008 | 09:38 PM
DeeGee's Avatar
DeeGee
Not sure about the plug and play. IIRC you need a lead but I could be wrong. Does this help?
Old Nov 21, 2008 | 09:43 PM
Black_6-Speed
What year did the cd changer/wiring show up? My Vette is a 97 and I would guess they didn't have it.
Old Nov 21, 2008 | 10:00 PM
Daytona Bob's Avatar
Daytona Bob
St. Jude Donor '09 & '12, '14
I had it in 01 but I had that option from Factory.
Old Nov 22, 2008 | 04:35 AM
Herringchoker's Avatar
Herringchoker
From: "Man been singin' the Blues, since he began to till the ground"...Vancouver, USA WA.
If I'm understanding your ?, it's located in the rear center storage compartment, thats where a stock 12 disc changer would be located.
Old Nov 22, 2008 | 05:03 AM
PostShawn's Avatar
PostShawn
My 99 has the CD changer option. The CD changer was in the rear middle compartment on the front facing wall. Pull up the carpet there and see if any wires are hanging around. I took my changer out to attach an iPod hookup.
Old Nov 22, 2008 | 09:18 AM
The NNIAL8R's Avatar
The NNIAL8R
St. Jude Donor '11,'13
"I voluntarily took 60 days off from OT"
The C5 is NOT equipped with a harness unless it came with a CD as an option....However, the harness is easily installed if you dont have a CD changer and want to install one....All it takes is pulling up a few pieces of carpet and trim along the passenger side of the interior....The two plugs for the harness are in the passenger side footwell under the liftout panel....
Old Nov 22, 2008 | 04:06 PM
dieseldave56's Avatar
dieseldave56
Default optional harness in C5............
I have found that the remote 12 disc CD changer harness came in some vehicles that never had the option filled. The FRC and Z06 never had the option so the wiring harness was never installed in those models ( I have three FRC and Z06 that I have installed the remote CD changer into).
If you have a harness it will be located as mentioned in the area of the center recess , on the outside verticle wall section ( facing the rear). As the CD changer is mounted vertically on this wall.
Your GM service manual shows the routing of the harness and the plug in at the passengers kick panel and foot well area.
http://forums.corvetteforum.com/c5-p...d-changer.html
http://forums.corvetteforum.com/c5-z...r-pigtail.html
http://forums.corvetteforum.com/c5-t...er-in-z06.html
[IMG][/IMG]
To Cd changer!!!!!????
