[Z06] When do you change the Diff fluid?
Old Jan 15, 2002 | 12:42 AM
Pio's Avatar
Pio
Default When do you change the Diff fluid?
Wondering at what mileage you change the differential fluid. Should I get it done at the dealership?
Thanks,
Old Jan 15, 2002 | 02:51 AM
Rollin Black's Avatar
Rollin Black
Default Re: When do you change the Diff fluid? (Pio)
Hello Pio.
I did mine at 5130 miles and am glad I did! The fluid was full of very fine metal flakes :eek: :eek:
Replaced it with Redline and have been very happy. Changed the Tranny fluid also, and it was in really bad shape.
I suggest you wait at least 5000 miles as C4C5 recomends that as a minimum for proper break in time. Then I do recomend that you change the fluids.
Also check your clutch fluid and if there is any discoloration change it also.
Thanks, Rollin
[Modified by Rollin Black, 10:54 PM 1/14/2002]
