Battery Tender Connection
Old Nov 22, 2008 | 04:30 PM
indy300's Avatar
indy300
Default Battery Tender Connection
this may be a dumb question, but is the C5 a positive or negative ground system?
I just bought a Battery Tender Junior and depending on the ground system, it says to hook one of the clamps to the chassis not the battery. Common sense says hook red clamp to positive battery terminal and black clamp to negative battery terminal.
how do you hook this thing up CORRECTLY?
Old Nov 22, 2008 | 04:35 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
For my tender, I connect the red (positive) connection to the red terminal on the battery and then connect the black (negative) connection to any metal point on the engine frame. I then plug in the tender.
After the charge, I unplug he tender and then disconnect the battery connections.
Old Nov 22, 2008 | 04:40 PM
FAAASTJEDI2000's Avatar
FAAASTJEDI2000
The c5 is a Negative ground system.
Old Nov 22, 2008 | 04:42 PM
ZBrink's Avatar
ZBrink
St. Jude Donor '06
After the charge? Tender's don't charge, they simply maintain don't they??
Old Nov 22, 2008 | 05:23 PM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
A tender will bring a battery back up to full charge, but it could take a loooong time. They work on a real low charge/tend rate. Look at the thickness of the cables compaired to a full house charger.
I ALWAYS hook up direct to the battery with BOTH terminals. The more direct the better.
Old Nov 22, 2008 | 05:35 PM
dieseldave56's Avatar
dieseldave56
Default Floating charge...........
Battery Tenders apply voltage as neccessary to maintain battery level. I alway disconnect the battery from the vehicles circuitry when charging so the charger is connected to each appropriate terminal.http://forums.corvetteforum.com/newr...1&p=1567940967
Old Nov 22, 2008 | 05:39 PM
chips*dad's Avatar
chips*dad
It SHOULD be a negative. It's specified in the BTender directions... look for the wire running off the neg post to your chassis, which is your confirmation that it is, as it should be, a negative ground, as others have said already - meaning you clamp the positive the run the other to the chassis, at least according to the directions. I have had people with formal training tell me what one poster here has also said - you should simply connect the positive to the positive, and then the negative to the negative post. Personally? I'm leaning on the directions, because if you do your own thing, and something bad happens, I suspect you're giving up any possibility you MAY have had to seek redress from the manufacturer.
My 2 cents...
Dave
z06Bigbird's Avatar
z06Bigbird
I am not sure American cars ever had positive ground. I suspect some foreign cars used to.
Anyone know about positive ground on old old Amer cars??
Old Nov 22, 2008 | 05:50 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I believe that most of the positive ground cars were in the 30's if I'm not mistaken.
I'm pretty sure that 12v became the norm in '56. At least I know that's true for Fords.
Old Nov 22, 2008 | 06:01 PM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
I believe there were a couple pre WWII cars with positive grounds. All modern day autos are negative.
My 31 (6 volt) stays attached to a Accumate hard wired to the terminals. The battery is under the passenger floorboard and a pain to access. I've got the leads are accessible in the trunk. Also, my 71 Olds has been hooked up to a Solar brand maintainer thru the terminals for the past 9 years, same Delco battery. of course neither have computers. I've always heard to hook up jumper or charger cables with the negative to a chassis ground and not directly to the battery
Old Nov 22, 2008 | 08:20 PM
dobewillie's Avatar
dobewillie
red to red black to black neg. ground
Old Nov 22, 2008 | 08:24 PM
oaks99's Avatar
oaks99
mine that i got from chip ( cca ) came with a cable to hook up to the battery and leave it there all the time and when you plug the tender in it just plugs to the cable , and ony goes in one way .
oak
Old Nov 22, 2008 | 08:28 PM
clayton1's Avatar
clayton1
Banned Scam/Spammer
BAtteries emit gas (hydrogen) which is explosive. Youre better off hooking the Neg away from the battery, such as frame. If everything is good your not going to lose much Voltage, if any, per connection.
Old Nov 22, 2008 | 11:50 PM
MSG C5's Avatar
MSG C5
A tender will bring a battery back up to full charge, but it could take a loooong time.** They work on a real low charge/tend rate.** Look at the thickness of the cables compaired to a full house charger.I ALWAYS hook up direct to the battery with BOTH terminals.* The more direct the better.
It usually takes mine overnight to work.* It provides a green/red LED readout that indicates a full charge.* It does recharge the battery, because I once left the Corvette in the garage for two weeks without driving it and when I tried to start it, it wouldn't ignite.* After I used the battery tender and recharged the battery, it started right up.*
Old Nov 23, 2008 | 02:26 AM
DeeGee's Avatar
DeeGee
I remember a friend who had an old MGA which was a positive ground. And I'm not sure if the reputation of electrical systems on British cars ever recovered. Not heard of other manufacturers who have used that system for many years
I hook my tender up to the battery posts and its worked fine for me.
Old Nov 23, 2008 | 06:13 AM
ljthe2nd's Avatar
ljthe2nd
I use the harness that came supplied with the Battery Tender, it is connected to the positive and negative terminals on the battery. The harness stays connected to the battery and it is designed to be a quick connect/disconnect. I've been using this setup for years, and it works fine.
Old Nov 23, 2008 | 06:21 AM
vetter79's Avatar
vetter79
Learned how to drive on a '28 Olds. 4 Dr. Sedan Pos ground there,
To Battery Tender Connection
