lowering my C5?
Old Nov 22, 2008 | 06:47 PM
sbiggs's Avatar
sbiggs
5th Gear
Default lowering my C5?
I need tips and tricks for lowering my C5. Im going to stay with the factory Chasis bolts, instead of aftermarket. Im sure it can get low enough? Do you screw in the front bolts and expand the back?
Old Nov 22, 2008 | 07:04 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Here is a good link that might help.
Bill K
http://www.z06vette.com/diy_lower.php
Old Nov 22, 2008 | 07:13 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Here is another good link that should help.
http://www.crossedflags.com/modules....der=1&sid=7#12
Old Nov 22, 2008 | 07:31 PM
Shagster's Avatar
Shagster
St. Jude Donor '10
Its not to bad to do I have lowered 3. I'm lowering a 4th one in the morning. All Z06s
I'm at 30 min. tops for the rear and 45 min. tops a side for the front. Good luck
Old Nov 22, 2008 | 09:52 PM
ncevette's Avatar
ncevette
what if you want it lower
Old Nov 22, 2008 | 10:09 PM
jrose7004's Avatar
jrose7004
If you want it lower, cut the bushings.
Old Nov 22, 2008 | 11:37 PM
Z06ster's Avatar
Z06ster
Here's a great post by a forum member. Look at the third thread. It helped me out
http://forums.corvetteforum.com/c5-t...ock-bolts.html
To lowering my C5?
