HUD access
Old Nov 22, 2008 | 08:22 PM
Mike McCoy's Avatar
Mike McCoy
Default HUD access
The other day someone mentioned being able to drop the driver's side kick panel and steering column assembly. Can you access the rear mounting tab screw on the HUD module without pulling the dash apart by doing this ?
Old Nov 22, 2008 | 08:58 PM
HawkIVette's Avatar
HawkIVette
If you are asking if you can get to the projector without removing the dash, I kinda doubt it.
When I installed my HUD, I remember a lot of dash support, wiring and other modules all below the projector, let alone the firewall, that I find it hard to believe you could actually access any connections on the projector without removing it from the top.
Besides, it's not as complicated as it sounds to remove the whole dash pad.
Old Nov 22, 2008 | 09:34 PM
sprinter1104's Avatar
sprinter1104
The back tab screws in from the top.
Old Nov 22, 2008 | 11:48 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I pulled the dash pad for the first time, replaced the HUD and put it all back in 2.5 hours. It wasn't hard at all.
Old Nov 23, 2008 | 03:27 AM
ColeTrain'sC5's Avatar
ColeTrain'sC5
no the dash pad is EASY to pull
Old Nov 23, 2008 | 10:45 AM
davek 515's Avatar
davek 515
You can take the dash out in less then half hour, I've done it twice installing HUD.
To HUD access
