another leaky butt
Old Nov 24, 2008 | 07:27 PM
buckg2's Avatar
buckg2
Default another leaky butt
heres the story bought 04 vert with an unknowing leaky butt. the dealer is cool to pay for the repair (no warranty). they want a estiment from the mechanic. how much can I expect this bill to be?
Old Nov 24, 2008 | 07:31 PM
71vetteinva's Avatar
71vetteinva
Wow. That was timely. I just noticed the drops on the garage floor yesterday and called the shop today. Mine is a 2000 with about 48k miles on it. It's the driver's side seal on the differential.
Old Nov 24, 2008 | 09:20 PM
patsfan's Avatar
patsfan
From: Swanton VT 2000 Navy Blue Mettalic M6 / 1991 Auto - Steel Blue 68,500 R.I.P
Old Nov 24, 2008 | 10:39 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Old Nov 24, 2008 | 10:46 PM
JDaniel's Avatar
JDaniel
St. Jude Donor '08-'09
If its an output seal.. just do it yourself. It took me about 45 minutes to do my first one and its easy as all get out! Give it a shot.
Old Nov 24, 2008 | 11:32 PM
DaBoz's Avatar
DaBoz
I had mine done under warranty. They told me the cost would have been $1200.00 at the dealership.
Old Nov 25, 2008 | 02:40 AM
DeeGee's Avatar
DeeGee
I had mine done under warranty back in Nov 03 in Vegas. From my invoice they booked $325 to GM at the time including parts and labor, although I guess those rates may have risen by now. It was quite a strip down at the rear end as I saw my car up on the lift. Not a job I'd tackle, particularly as the dealer is happy to do the work.
Old Nov 25, 2008 | 03:13 AM
PostShawn's Avatar
PostShawn
I was quoted $500 at a Corvette shop that is usually a little high priced. I've heard that number is the average and you can expect $400-600 on the pricing.
Old Nov 25, 2008 | 07:43 AM
RedSoxFan's Avatar
RedSoxFan
My dealer charged me about $400 a few months ago for the repair.
Old Nov 25, 2008 | 08:01 AM
rwlc5's Avatar
rwlc5
I need to get it done and my mechanic (ex-GM mechanic that specializes in corvettes) quoted $350.
Old Nov 25, 2008 | 09:01 AM
buckg2's Avatar
buckg2
Default leaky
to me it looks like the side cover, and would it be smart to redo both side covers and both axle seals while its apart or just fix whats broke?
Old Nov 25, 2008 | 09:07 AM
kww's Avatar
kww
Yep I've heard dealerships charging as much as $1200 to replace the seals. But I'll tell you for that kind of money I'd go to ECS and have them replace the seals and put in a set of 370 or 410 gears to boot.
Old Nov 25, 2008 | 10:25 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
You're getting into alot of extra labor if you do the side that's not leaking. It's almost always the driver's side diff. cover. You will also want to do the axle bearing seal while you have that side apart.
Did mine at home on my lift last month in about two hours. I believe the dealer's book allows about 2 hours for the repair. It's labor only as the parts are next to nothing. My car was leaking with only 9,000 miles on it. Bad design. They relied on an o-ring to seal the side cover. It needs the sealant applied to keep it from leaking. About $450 at dealer prices. Use the GM synthetic rear diff fluid and 1 4 0z bottle of GM posi lube.
Old Nov 25, 2008 | 05:36 PM
austinmc's Avatar
austinmc
got the whole thing done to mine in the spring the dealer charged $275. They forgot to add the cost of the syn gear oil, but did not charge me for it. Mine is a 2000 A4 and had about 36,000 on it at time.
Old Nov 25, 2008 | 09:14 PM
DINO84's Avatar
DINO84
Did you just buy it?Does your state require a vehicle inspection?Is the leak listed on the inspection sheet?I doubt it just started leaking.Maybe you could use the sheet to guilt them into paying?
Old Nov 25, 2008 | 09:41 PM
redrider's Avatar
redrider
Driver's side differential seal leak is an epidemic with these cars. It seems like every one will fail sooner or later. Just had mine done at 50K miles at a Corvette specialty shop. It seems the real cause of the problem is poorly designed vent at the top of the differential that clogs over time. Once that happens, pressure builds in the differential beyond the seal capability. Have to clean out the vent to keep it from happening again sooner rather than later, but it will most likely happen again if and when the vent clogs.
To have it done right, its about 2 1/2 hours labor plus parts and fluids. Would have been around $350 were it not for coverage by my extended warranty.
Old Nov 26, 2008 | 06:00 AM
Black 'n Tan's Avatar
Black 'n Tan
St. Jude Donor '07
Is the axle vent removable? I used to remove the axle vents off Ford trucks, (steel) re-drill them out to 1/8" and never had a seal blow out again. Could it be we have the same problem with the 'vette rear?
John
To another leaky butt
Old Nov 26, 2008 | 07:57 AM
Tom/99's Avatar
Tom/99
John
Good question!
Old Nov 26, 2008 | 08:50 AM
capevettes's Avatar
capevettes
CF Community Team
2016 C2 of Year
If you can move the vent tube up an down it is operating properly. MIne was functioning fine but the rear end side cover was still leaking. With the poor design of the side cover seal it's destined to leak regardless.
Old Nov 26, 2008 | 10:36 AM
Frans96ss's Avatar
Frans96ss
St. Jude Donor '09
I would just fix the seal that is leaking unless the other on looks wet around it also. Not sure how far you are from me but if you need someone to fix it feel free to PM me.
