Is my engine over heating??
Old Nov 26, 2008 | 08:03 AM
Borrega's Avatar
Borrega
Default Is my engine over heating??
Not really sure why but my temp. moves to 240! is it because it needs change of antifreeze or new thermostat! help please
Old Nov 26, 2008 | 08:07 AM
damilleniumboy's Avatar
damilleniumboy
You need to look at and clean your radiator. It's probably clogged with junk that it has vaccumed in to the fins over time.
Old Nov 26, 2008 | 08:24 AM
stormrider's Avatar
stormrider
Old Nov 26, 2008 | 08:49 AM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Many Corvettes overheat because they get junk in front of the radiator ! !
Old Nov 26, 2008 | 08:55 AM
steve8's Avatar
steve8
Definitely a good place to start. A lot of crap can accumulate there.
Old Nov 26, 2008 | 09:01 AM
BT-01-vette's Avatar
BT-01-vette
needs to be done after the leaves fall. You would not believe how much gets sucked up there!!
Old Nov 26, 2008 | 09:19 AM
itzza427's Avatar
itzza427
You weren't Very clear in your post,,what conditions is it reaching this temp? All the time,sitting in traffic on a hot day and so on. According to the tech guys in the corvette magazines 240 isn't all that high under certain conditions. That said check the radiator/AC condenser fins for junk. You always want maximum air flow through there!!
Old Nov 26, 2008 | 09:57 AM
Dominic Toretto's Avatar
Dominic Toretto
I will be looking to do the same thing also. Mine does not reach that temp but it is getting hotter than I care for. I actually took a look around yesterday to see how to get to it, Chevy covered the radiator up pretty nice so it will probably take awhile to get to it.
-Alex
Old Nov 26, 2008 | 01:22 PM
BT-01-vette
-Alex
Drive up some ramps and look from underneath. I use a long thin stick and carefully waved it from right to left to removed the build up of leaves and etc.
Old Nov 26, 2008 | 01:29 PM
RLYSLO's Avatar
RLYSLO
St. Jude Donor '08
-Alex
you can remove the air intake bridge and then the radiator upper support cover to get in there.
Old Nov 26, 2008 | 01:34 PM
Bill Dearborn's Avatar
Bill Dearborn
You need to explain more of the operating conditions. It is possible to see 240 or more when in traffic or where the car isn't moving much. If your temperature is normal 190 to 200 while driving at 55 to 60 your cooling system is OK.
Here is how the fans operate:
The low speed cooling fan is commanded on when the coolant temperature reaches 108°C (226°F). It is turned off if the coolant temperature lowers to 104°C (219°F). The high speed cooling fan is commanded on when the coolant temperature reaches 113°C (235°F). It is turned off if the coolant temperature lowers to 108°C (226°F). When the A/C is on and the coolant temperature reaches 85°C (185°F), the low speed cooling fan will be turned on at vehicle speeds less than 56 kPh (35 mph).
Bill
Old Nov 26, 2008 | 01:44 PM
That is a bit high on the temp. I agree with looking at the radiator area under the front fascia and see if debris is there. If not, then check further in the system.
Old Nov 26, 2008 | 02:22 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Old Nov 26, 2008 | 02:48 PM
DeeGee's Avatar
DeeGee
I imported a Walmart plastic bag into England in my air intake
Old Nov 26, 2008 | 03:00 PM
damilleniumboy
There was a forum member that had a frog stuck in his. It was on a recent post.
Old Nov 26, 2008 | 05:17 PM
Borrega's Avatar
Borrega
WEll im in houston so the weather is good condition in 70s an when i drive it goes down no normal 220degrees but when i slow down or stop it goes up too 240degrees!
Old Nov 26, 2008 | 05:20 PM
Dominic Toretto
I would be concerned about a normal driving temp of 220F. I know it can do that, but I usually turn on my heater to keep it around 198-205F. Maybe I am paranoid.
-Alex
To Is my engine over heating??
Old Nov 26, 2008 | 05:33 PM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
-Alex
220 is way above average operating temps for me. I usually run about 194-196 degrees with the stock thermostat. But mine has been tuned so that the fans will both kick on if it hits 200. Highest I've seen mine is about 215 or so. And that was sitting in traffic, AC on, hotashell outside.
Old Nov 26, 2008 | 06:40 PM
damilleniumboy
Originally Posted by 2000lambovette
Went under the car yesterday to change the oil. I looked up into my radiator area and saw this frog all dried up. I`ve had lots of other things caught up in there but never a frog, maybe its time for the mesh cover.
check this thread
http://forums.corvetteforum.com/c5-g...er-a-frog.html
Old Nov 26, 2008 | 07:52 PM
dobewillie's Avatar
dobewillie
a lot of good suggestions many of the post could be the cause start with inspecting and cleaning the rad check fluid level and condition of anti freeze good luck
