Battery Tender... questions
Old Dec 2, 2008 | 08:22 PM
Alaskanpilot's Avatar
Alaskanpilot
St. Jude Donor '08-'09-'10
Default Battery Tender... questions
I have some questions about battery tenders.
About all I know is that they do something to help the battery. Do they basically plug into a wall, then connect to your battery, and keep it charged while the car sits for some length of time? Are these intended to be set up, plugged in, and left plugged in the entire time? Or, do they only need to be used for an hour here, an hour there?
What's the difference, if any, between these and trickle chargers?
I'd like to buy the right item for my Vette, which is stored this winter. So far I back it out of the garage every week or two and let it run for a bit and warm up to temp, but I wont always be able to do this. Maybe this isn't even the best way. But until I get the alternatives straightened out, I'm stuck.
What do I need, so that come April my Vette will start right up?
FWIW, I'm looking at this offering from AutoGeek:
http://www.autogeek.net/btplus.html
Old Dec 2, 2008 | 08:29 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
I use for the last 10 years Battery Tender Jr, connected to the car when I am not using it for weeks. I have it setup with a quick disconnect that comes with the unit.
What it does is keep the battery up to standards, and than turns off and on when needed to keep the battery fully charged.
Old Dec 2, 2008 | 08:33 PM
Alaskanpilot
OK, so basically I can plug the thing in and hook it up, and it monitors itself? It can stay plugged in and hooked up for months at a time?
Old Dec 2, 2008 | 08:34 PM
BLKBLUR's Avatar
BLKBLUR
I have had a Battery Tender Plus for five years or so. What 1bdvet said is correct. It charges as needed. I use it on and off on my tractor and my pickup (which sits a lot). Great investment. My brother has one and uses it on his boat batteries too.
Old Dec 2, 2008 | 08:35 PM
DropTheTop's Avatar
DropTheTop
I have used the battery tender, and battery tender junior in the past. They just plug in, and you can leave them plugged in for long time storage. But that is all they do. Now I have two CTEKs. One of them has the ability to be put in a supply mode, which basically means that I can mess with the car's stereo or whatever, without the car running - and the battery won't drain. It also has as setting that can rejuvenate batteries that don't quite hold a long charge anymore. It's not guaranteed to bring a battery back to life, but with regular use it will keep your batteries in top form. My other CTEK is good for all other my other charging uses during winter, which I bounce around from tractor to ATV to Bike, etc... The CTEKs can withstand some extreme conditions, such as being run over and getting wet. Whatever you pick, it will keep your battery good for storage.
Old Dec 2, 2008 | 08:37 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
That's what it does alright!
Old Dec 2, 2008 | 08:42 PM
Alaskanpilot
Great replies! Sounds like what I need.
STL94LT1's Avatar
STL94LT1
Old Dec 2, 2008 | 08:44 PM
Patches's Avatar
Patches
I've been using a Battery Tender Plus on my '02 C5 for over 6 years now and that's almost continuously except when I take it out for the occassional good-weather weekend drive. I have thousands of hours on that Battery Tender with never a problem. It has kept my Optima Red Top battery in primo condition since 2002 when I had to replace my 9-month-old stock battery after it went south shortly after buying the car.
The tender will slowly charge the battery to it's proper charge level and then go into a maintenance mode and keep it in optimum condition. Some chargers do not discriminate with respect to the type of battery and so are not a good choice for certain types such as glass mat. There is some "intelligence" built into some chargers where they can adjust to the type of battery and apply the appropriate charging profile to fit the battery. The Battery Tender is a good choice as is the Ctek unit Willfulone sells on his site. There are several others worth looking at out there as well. Do a search and I'm sure you'l find a ton of info.
The BT can bring back a weak battery but not one that is completely dead. As mentioned abouve, the Ctek can often revive a dead battery. Neither can bring back a battery with a dead cell though.
Old Dec 2, 2008 | 08:47 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Peace
Chip
__________________
..................Click for
Old Dec 2, 2008 | 08:51 PM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
Tis the season to CTEK!
Old Dec 2, 2008 | 09:35 PM
countslav's Avatar
countslav
Where you live.........Don't leave home without it.....
Old Dec 2, 2008 | 09:37 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Originally Posted by Willfulone
Yup! I have 2 BT's -- one on my bike, one on the Vette
My DD doesn't need one... yet
Old Dec 3, 2008 | 05:57 AM
bronxbill's Avatar
bronxbill
I have used Battery Tenders on my motorcycles for years, great items. Rather than paying $50 for a real Tender, you can get one that works just as well from Wally World for $20, mine works great.
Old Dec 3, 2008 | 06:53 AM
DAV162's Avatar
DAV162
Old Dec 3, 2008 | 11:26 AM
gpotski's Avatar
gpotski
I use the Battery Tender Plus when my C5 sits over winter. Just plug it in, attach to the battery, and let 'er sit for weeks/months at a time.
Old Dec 3, 2008 | 01:13 PM
When I had my C5, I used a Battery Tender Plus on it and kept it plugged in and connected to the battery any time I was not driving the car. The Tender automatically charged the battery at a sufficient rate to keep it fully charged.
To Battery Tender... questions
Old Dec 3, 2008 | 05:49 PM
Alaskanpilot
Thanks for the help everyone! I ended up getting the Battery Tender Plus from Autogeek. I was placing an order anyway so there wasn't really any additional shipping charge for throwing it in.
I was very tempted to order the CTEK, it sounds fantastic too! But when you live in Alaska, complete with outrageous shipping charges, it's best to order from as few places as possible. I think I'll be good to go when the BT Plus arrives.
Old Dec 3, 2008 | 06:38 PM
grayfox2424's Avatar
grayfox2424
For some really great battery tenders check out one of your local boating stores..these are very good heavy duty units..much better than the auto stores & Wal-Mart sell.
Old Dec 3, 2008 | 09:04 PM
dobewillie's Avatar
dobewillie
black and decker at walmart 15 bucks works great
