I've had trouble with the L/F headlight (low beam only) sometimes not coming on, then finally a couple days ago the light stopped coming on all together. I took the bulb out and it looked good, and to rule it out I switched it with the R/F, it works perfectly. So something is wrong in the wiring, I cleaned the ground behind the light and it didn't do anything so if someone has a schematic I would greatly appreciate it.
Also interior wiring, my lights in the visor mirrors has never worked, if anyone has that also.
Thanx
Roy
Try fuse #2 in the passenger footwell for the visor lights.
