Need Help Repairing a Ding
Old Dec 9, 2008 | 02:49 PM
JDC1999's Avatar
JDC1999
Default Need Help Repairing a Ding
Hiya all,
I was hoping that it would be much longer before I asked for help on this subject, but alas the dreaded has happened.....Happy Frickin' Holidays!
Anyway, the ding is more of a "rub" or "brush" where the other vehicle's door hit mine. There does not appear to be paint removed from my car, but it looks like paint has been deposited by the other door.
I am hoping that I can buff it out with my Flex buffer, but I am strictly and amateur and have very little confidence in undertaking a major "paint project."
Any and all suggestions would be greatly appreciated (other than park further away). Please no smart a$$ remarks.
Thanks, Mike
Old Dec 9, 2008 | 06:46 PM
rob-cyn's Avatar
rob-cyn
I would not buff your paint with the other paint still on there. I would try to get the other paint off first so your buffer does not pick it up and scratch your paint.
Old Dec 9, 2008 | 06:54 PM
DAV162's Avatar
DAV162
Old Dec 9, 2008 | 06:57 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Try going over it very gently by hand with DuPont polishing compound.
Old Dec 9, 2008 | 07:00 PM
71vetteinva's Avatar
71vetteinva
What have you tried so far? Perhaps a clay bar could remove some of the old paint?
Old Dec 9, 2008 | 07:04 PM
Ryan040675's Avatar
Ryan040675
Turtle wax makes a product in a green can called "clear coat polishing compound". I would try a little of that on a soft, damp cloth and rub it gently. See what happens..You won't hurt anything as long as you're gentle. I'll bet it comes right off as long as the paint isn't scratched/burnt.
Old Dec 9, 2008 | 07:07 PM
RedLS1GTO's Avatar
RedLS1GTO
Had a friend with a similar situation and the clay bar took it off like a freaking eraser. I was absolutely amazed.
Old Dec 9, 2008 | 07:54 PM
dobewillie's Avatar
dobewillie
try a clay bar first good luck
Old Dec 9, 2008 | 07:58 PM
BOTYNV1's Avatar
BOTYNV1
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Will probably take it right off.
Old Dec 9, 2008 | 08:13 PM
jobear's Avatar
jobear
clay bar
Old Dec 9, 2008 | 08:17 PM
jrose7004's Avatar
jrose7004
I'd use clay bar.
Old Dec 9, 2008 | 09:33 PM
JDC1999's Avatar
JDC1999
Thank you all. I hadn't thought about the clay bar. I will try it and let you know how it works.
Mike
To Need Help Repairing a Ding
