are all stock c5's the same?
Old Dec 13, 2008 | 01:18 PM
daniel5625's Avatar
daniel5625
Default are all stock c5's the same?
are the bodys of the stock c5's 97-04, the same, or do they change a little every year, they all look the same, let me know about the convertables also.
thanks!
Old Dec 13, 2008 | 01:23 PM
yelloyello's Avatar
yelloyello
CI 6-7, 9-10 Veteran
For the C5's there are only a couple of variations of body styles:
Coupe=the only difference is body side moldings
FRC/Z06= does not have a 'hatch' like the Coupes. same with BSM's
Convert=top goes down.
If interested, there are many companies that can sell you parts to change the body styling.
Old Dec 13, 2008 | 01:28 PM
daniel5625's Avatar
daniel5625
is the back of the c5 verts all the same width?
Old Dec 13, 2008 | 01:30 PM
Bill Dearborn's Avatar
Bill Dearborn
Yes. The only differences between years on C5s is the removal of the passenger side door key hole.
Bill
Old Dec 13, 2008 | 02:11 PM
damilleniumboy's Avatar
damilleniumboy
They also have different wheels. They went from waggon wheels to thin spoke wheels. The 97-99 have a black exhaust, and from 00-04 they have chrome tips.
Old Dec 13, 2008 | 02:29 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
The stock dimensions of all three body styles are exactly the same, throughout the entire model run - 1997 to 2004.
Old Dec 13, 2008 | 02:42 PM
El Zappo's Avatar
El Zappo
From: Remember the average response time to a 911 call is over 6 minutes. The average response time of a .357 magnum is 1400 fps.
'00 have black tips.
Old Dec 13, 2008 | 02:52 PM
There really weren't many changes over the course of the C5 model - at least not in the appearance department. Just goes to show you that they knew not to mess with a good thing.
Old Dec 13, 2008 | 03:00 PM
GrandSportRob's Avatar
GrandSportRob
The 97-99 C5's had ugly rims we refer to as "wagon wheels"...If you buy one of those as I did, PLEASE replace the rims!!
Old Dec 13, 2008 | 04:59 PM
jraschke11's Avatar
jraschke11
St. Jude Donor '08-'09-'10-'11-'12-'13-'14
Old Dec 13, 2008 | 05:56 PM
cookrent's Avatar
cookrent
St. Jude Donor '08
Some are different colors
Old Dec 13, 2008 | 07:41 PM
dobewillie's Avatar
dobewillie
c5s are all pretty much the same some minor variations in the generation
Old Dec 13, 2008 | 07:56 PM
DAV162's Avatar
DAV162
Not mine. Chrome.
Old Dec 13, 2008 | 08:00 PM
2KFRC5's Avatar
2KFRC5
Originally Posted by DAV162
Not mine. Chrome.
Mine's early production. Black
Did you buy new? Aftermarket exhaust?
Old Dec 13, 2008 | 08:13 PM
Nightstick's Avatar
Nightstick
Bill
Great, now when I get home I'm gonna have to check if mine has a key hole or not.
Old Dec 13, 2008 | 08:18 PM
Johnny_B_Good's Avatar
Johnny_B_Good
St. Jude Donor '05 thru '26
• Completely new, redesigned Corvette. Base (FE1) and Z51 (FE3) suspension packages.
• All Z51 cars include: Power Steering Cooler
• 97-00 C5 LS1's produce 345 HP @ 5600 RPM and 350 Ft Lbs of torque @ 4400 RPM.
1998
• Convertible becomes available
• Active Handling becomes available late in year
• The two slots of a 1998 (and possibly late 1997s) curve toward the rear at the bottom. (versus straight down)
1999
• 26# injectors substituted for 28#
• Fuel pump revised to reduce noise
• FRC "Fixed Roof Coupe" aka the hardtop, becomes available. All FRC's are MN6 (6-speed) cars with the Z51 suspension package, and are about 60lbs lighter than coupes.
• HUD introduced
• Only one line in driver's side fuel rail cover (no fuel return line?)
• Power telescoping wheel becomes an option
• Steering hardware changed to combat wandering
• Door sill trim plates added
2000
• Millennium Yellow available
• "Thin Spoke" versus "wagon wheel" design wheels become standard.
• Pup cats added to all models for LEV emissions requirements (5hp loss relative to 97-99)
• Steel swaybar endlinks instead of plastic on Z51 equipped cars
• Z51 swaybar diameters grow (25.4/21.7 to 28.6/21.7 to 28.6/23.6 (note: new rear same as Z06)
• No keyhole on passenger side doorhandle
• Passenger airbag 'off' switch added to console (light by TC/AH button)
2001
• Return to 28# injectors for all models.
• Second Generation Active Handling
• Nassau Blue discontinued
• Alternator 'clutch' pulley added on A4 cars
• New soundproofing + foam in all cars
• Smaller keyfob
• Electrochromic dimming rearview and driver's mirrors
• Lighter AGM battery
• Thickness + Material in Convertible change
• Chrome exhaust tips for coupe + Convertible
• 85MM MAF with integral temp sensor (versus 74mm with separate plug for IAT)
• LS1 cam profile changed to: .500/0.500, 198/208 on 115.5LSA (From: 0.472/0.479, 202/210 on 117)
• All Corvettes now have the LS6 intake manifold
• All Corvettes now have the LS6 engine block (windage passages in block), which includes a beefier oil pump.
• LS1 changes result in new output of 350 HP @ 5200 RPM and 375 Ft Lbs of torque @ 4400 RPM (MN6)
• Hardtop/FRC discontinued
• Stronger synchros in all transmissions
• Exhaust manifolds revised (5hp regained) - thin wall cast replacing SS manifolds
• Metal valvestem caps (late year)
• Torque Tube changed from metal-matrix composite to aluminum alloy 6061, increased in diameter from 55 to 63 mm.
• Driveshaft couplings have also been upgraded on manual-equipped models for additional strength and durability
• Introduction of the Z06, which has as differences:
• Hardtop body style
• Rear brake ducting
• Screened inlets on front fascia, without foglights
• F1 Supercar tires 265-17 front, 295-18 rear, on 17x9.5 and 18x10.5 (one inch wider, respectively
• New LS6 top-end with new style head design (10.5:1 compression, 64cc chamber), LS6 cam (0.525/0.525, 204/211 on 116) - 385hp
• M12 transmission with shorter gearing (1-2-3 analagous to MN6 with 3.90 rear diff
• Titanium exhaust system
• Lightweight windshield
• New, stronger clutch with redesigned master + slave cylinder
• Stronger rear differential (shotpeened ring gear)
• Red brake calipers (otherwise identical)
• Transmission overtemp warning light on DIC
• 6500 redline gauges with special checkering + Z06 font
• Redesigned PCV system to help combat oil burning
• Red LS6 Fuel Rail Covers (FRC's)
• FE4 Z06 suspension - uprated springs, bars (30mm/23.6mm), shocks (note front spring and rear bar same as Z51)
2002
• Z06 Changes:
• Z06 LS6 cam changed to: 0.551/0.547, 204/218 on 117.5
• Less restrictive intake airbox lid
• Descreened MAF
• Removal of pup-cats (total with changes = 405hp)
• Z06 shocks revised with less rebound for better launching
• Z06 brake pads revised for better stopping (generate more dust)
• Lighter, sodium filled valves w/ stronger valve springs
• Higher tension rings installed to prevent oil burning problems
• Slight piston redesign *
• Clutch strength upgraded.
• HUD available on Z06 (not avail '01 model year)
• Wheel supplier changed to Speedline, moved from forged to cast. Weight nearly identical
• Electron Blue color offered
• Steel endlinks changed to aluminum
2003
• Late model-year new fuel system design from C6's
2004
• Z06 shocks further refined. Accompanying upper front control arm bushing, and rear swaybar bushing changes.
Old Dec 13, 2008 | 08:23 PM
2EZ 2SPD's Avatar
2EZ 2SPD
mine were changed before I got it
To are all stock c5's the same?
Old Dec 13, 2008 | 08:33 PM
2KFRC5's Avatar
2KFRC5
A couple of corrections. There may be more.
2000
• Pup cats added to Calif. & N.E. models for LEV emissions requirements (5hp loss relative to 97-99)
LS1 cam profile changed to: .500/0.500, 198/209 on 115.5LSA, 112/119 Timing Made up for the 5 HP loss ?
Steel front only, rears remained plastic on Z51
• Passenger airbag 'off' switch added to console Mid model year (light by TC/AH button)
2001
• Smaller keyfob
LS1 cam profile changed to: .500/0.500, 198/209 on 115.5LSA, 112/119 Timing 2000 model year, not 2001
2001 went to .479/.467, 207/196,116LSA 117/115 Timing
• FE4 Z06 suspension - uprated springs, bars (30mm/23.6mm), shocks (note front spring and rear bar same as Z51).........
Old Dec 13, 2008 | 08:53 PM
Nightstick's Avatar
Nightstick
"2003
• Late model-year new fuel system design from C6's "
How do you define late model? Just wondering about mine. Thanks.
Old Dec 13, 2008 | 10:17 PM
El Zappo's Avatar
El Zappo
Not mine. Chrome.
What year do you have? Your profile says 2000, but a post of yours states 2001.
http://forums.corvetteforum.com/1568153069-post2.html
