Creaking??
Old Dec 15, 2008 | 10:34 AM
Dominic Toretto's Avatar
Dominic Toretto
I'll have to give this a shot now. Does the car need to be lifted very high to get to the bushings?
-Alex
Old Dec 15, 2008 | 10:53 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
-Alex
No lifting is needed to reach the stabilizer bushings with spray.
I like to have the wheels off to get the rest of them.
Old Dec 16, 2008 | 04:47 AM
NC99's Avatar
NC99
Originally Posted by chrismullins99
I hope hes talking about Liquid Wrench brand silicone spray...they have a few different products now
Yep, the silicone spray.
FUNCTION AND APPLICATION: A general-purpose silicone lubricant in aerosol form. Stops squeaks, rust and corrosion. Excellent mold release. Brightens rubber, vinyl and leather. Protects aluminum and
chrome from pitting.
Old Dec 16, 2008 | 05:01 AM
NC99's Avatar
NC99
-Alex
I ran the car up on my ramps and was able to reach them all. For the rear bushings, they are right there and no need to lift at all. Usually things are never this easy and actually work. This time the little guy won!
Old Dec 16, 2008 | 07:07 AM
Quicksilver Vert 01
Originally Posted by NC99
I ran the car up on my ramps and was able to reach them all. This time the little guy won!
Old Dec 17, 2008 | 05:21 AM
NC99's Avatar
NC99
FYI,
That can of silicone spray that posted the pic of, has petroleum distillates in it!
I went to Napa after work and bought a can of silicone that's not petroleum based and used that last night. Liquid wrench (Gunk products) does make a non-petro based silicone in a white can, but I couldn't find it anywhere.
Old Dec 17, 2008 | 10:07 AM
Quicksilver Vert 01
FYI,
Good info. NC99. I'm glad you found the right stuff.
Old Dec 17, 2008 | 10:49 AM
Tannman's Avatar
Tannman
Originally Posted by Oldvetter
It is probably your sway bar rubber bearings. They must be taken off to lube, lube with dielectric silicone grease.
You can also replace them with polyethene bushings from Ecklers (they come with special grease).
Old Dec 17, 2008 | 03:25 PM
mcgilles's Avatar
mcgilles
can someone post pictures of the areas that need to be lubed/ should they be lightly sprayed, medium, or soak them?
