Creaking??
Old Dec 14, 2008 | 06:48 AM
NC99's Avatar
NC99
Default Creaking??
My '99 creaks whenever I go over speed bumps, pull into the driveway etc. Is more likely to be the shocks or springs? How would I tell? Thanks.
Old Dec 14, 2008 | 08:50 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
It could just be dry rubber bushings at the mounting points of either of the above.
The upper and lower control arms, as well as the stabilizer bar, also have rubber bushings that may be dry.
Try spraying them all with silicone spray to see if it helps. It's best to remove the wheels to get better access to everything.
Old Dec 14, 2008 | 09:12 AM
One of my cars did the same thing and replacement/lubricating of the bushings did the trick.
Old Dec 14, 2008 | 09:36 AM
NC99's Avatar
NC99
Awesome advice! Thank you!
What is a good silicon spray?
Old Dec 14, 2008 | 09:38 AM
csexton's Avatar
csexton
Lubricate those sway bar bushings.
Chuck
Old Dec 14, 2008 | 09:53 AM
NC99's Avatar
NC99
Old Dec 14, 2008 | 10:11 AM
jraschke11's Avatar
jraschke11
St. Jude Donor '08-'09-'10-'11-'12-'13-'14
Something as trivial as silicone spray, it doesn't really matter. Walk in to the closest Lowes, Wal-Mart, or Autozone and pick up a spray can. It's one of those things that it's basically all the same.
Old Dec 14, 2008 | 10:32 AM
tbar1963's Avatar
tbar1963
St. Jude Donor '08
My vert "creaks" , but mine I think is all the plastic interior parts rubbing against each other...Too bad they didn't use a little felt in between some of those parts....
Old Dec 14, 2008 | 10:36 AM
FLATOUT's Avatar
FLATOUT
Temporary Hold
From: www.modular-concept.com www.flatoutimaging.com
Sounds like a good project Tom!
Old Dec 14, 2008 | 10:49 AM
tbar1963's Avatar
tbar1963
St. Jude Donor '08
Good morning Andy
Old Dec 14, 2008 | 02:11 PM
Oldvetter's Avatar
Oldvetter
It is probably your sway bar rubber bearings. They must be taken off to lube, lube with dielectric silicone grease.
You can also replace them with polyethene bushings from Ecklers (they come with special grease).
Old Dec 14, 2008 | 05:37 PM
gpotski's Avatar
gpotski
Chuck
It's probably the sway bar bushings and NOT the shocks or springs.
Old Dec 14, 2008 | 05:51 PM
Quicksilver Vert 01
The silicone spray I have is the store brand from ACE hardware stores.
Just make sure it's silicone, you don't want anything made with petroleum on rubber bushings.
Old Dec 14, 2008 | 06:57 PM
Oh 2 Fun's Avatar
Oh 2 Fun
St. Jude Donor '09, '13, '15
I have yet to find any more, but the best damn can lubricant I've EVER seen was lanolin based. Yes, sheep lanolin.
It was a great penetrant and lasted. Plus, it was just way slick. Amazing stuff.
Old Dec 14, 2008 | 07:03 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
I know I have noise in my interior from the plastic parts rubbing together?
Old Dec 14, 2008 | 07:06 PM
HawkIVette's Avatar
HawkIVette
I heard creaking, or more like a squeaking and thought it was from the outside. But finally narrowed it down to the rocking seat problem that the C5 is known for.
Are you sure it is coming from the outside?
Old Dec 14, 2008 | 07:08 PM
mcgilles's Avatar
mcgilles
I have the same problem. reminds me of the sound of a aircraft touching down. I'll have to give this a try also!
To Creaking??
Old Dec 14, 2008 | 09:30 PM
NC99's Avatar
NC99
I bought some liquid wrench, sprayed all the bushings I could find and quiet as ever now. The bushings are in fine shape, just needed a little squirt here and there.
Old Dec 15, 2008 | 07:26 AM
Quicksilver Vert 01
Liquid Wrench is not good for rubber. It has pertoleum distillates in it, which may be harmful to rubber.
As mentioned before, you should use only SILICONE on rubber.
Old Dec 15, 2008 | 10:31 AM
chrismullins99's Avatar
chrismullins99
I hope hes talking about Liquid Wrench brand silicone spray...they have a few different products now
