[Z06] MAX HP for stock injectors?
Old Dec 14, 2008 | 12:00 PM
1slowride's Avatar
1slowride
Default MAX HP for stock injectors?
Just as the title says, I am wanting to know when you need to upgrade from the stock injectors to bigger ones?
Old Dec 14, 2008 | 12:12 PM
lbarnard's Avatar
lbarnard
A tuner should be able to tell you what duty cycle your injectors are running at.
Old Dec 14, 2008 | 12:16 PM
TheDingo's Avatar
TheDingo
^ +1
Old Dec 14, 2008 | 01:48 PM
lar66BB's Avatar
lar66BB
Default injectors
I have seen posts from some tuners that say stock injectors are
good up to 500hp. But, that is maxing them out.
Old Dec 14, 2008 | 02:06 PM
lbarnard's Avatar
lbarnard
I have 440hp/430tq and mine were at 100% of the duty cycle. The best way to know is have a tuner check.
Old Dec 14, 2008 | 03:06 PM
falcon5619's Avatar
falcon5619
It also depends how lean/rich you are at WOT. Assuming 12.5-12.8 AFR the stock 28.8lb/hr injectors will be above the recommended 80-85% at about 375rwhp. At 432rwhp I was at 99%-101%, I just replaced the stockers with SVO 30lbs, and now my injectors are at a max of 77%, at 12.7-8 AFR up top.
So 500hp at the crank sounds about right for a completely maxed out 28.8 stock injector.
Old Dec 14, 2008 | 04:57 PM
bullitt4110's Avatar
bullitt4110
Yup I was mid 430's when mine where maxed out.
Old Dec 14, 2008 | 05:43 PM
1slowride's Avatar
1slowride
Thanks guys, you have been a big help.
To MAX HP for stock injectors?
