Battery ?
Old Dec 15, 2008 | 07:27 PM
nomocrap's Avatar
nomocrap
Default Battery ?
I have a 2002 Zo6 Having battery not holding a charge. What battery would be suggested. THANX
Old Dec 15, 2008 | 07:32 PM
mcgilles's Avatar
mcgilles
I have an optima yellow top in mine. many will claim that optima has issues with reliability (failing before they should) but mine's been fine. I would be open to an alternative brand but I don't know of any that make a similar product.
make sure you get a gel battery, not a liquid one. your PCM is under your battery and if a liquid battery leaks you are in for some costly repairs.
also if you have alot of electronics and ever find yourself running the battery down for some reason, consider a deep cycle battery. they sometimes don't have as much CA and CCA (plenty to start your car) but they can handle being discharged better. normal batteries loose some life if they are drained.
Old Dec 15, 2008 | 07:33 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I have had great service using Delco...
Old Dec 15, 2008 | 07:35 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Red top here, but I use a float charger as my C5 is not a DD
Old Dec 15, 2008 | 07:39 PM
DAV162's Avatar
DAV162
Delco here
To Battery ?
